Results 1 to 12 of 12
Thread: Easiest way to maintain pool
    What would you people consider the easiest way to maintain your pool least amount of time spent testing and adding chemicals. Not the cheapest way but most convenient way that takes least amount of time.
    30' round AG pool 21,200 Gallons, 52" high, 1 1/2 HP Pump;
    25" 300lb. Cooper Ranger sand filter .
    Re: Easiest way to maintain pool
    Quote Originally Posted by mike3554
    SWCG, automatic cleaner, and automatic cover.
    17,000 Gallon plaster pool. Hayward Perflex EC65 DE Filter. 3/4 HP Hayward Superpump converted to dual speed. CircuPool RJ45. Skimmer, floor drain, two returns.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by jparr
    I agree, but daily testing is still required (recommended). It sounds like OP is looking for a hands off approach, which is not advocated at TFP.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    We haven't been pool owners for very long, but with BBB, no problems and it's easy!
    I do all my own tests, no time wasted running to the pool store with water samples. Run tests for FC, add some liquid bleach when required, vacuum some leaves once and a while and we have crystal clear water. Most of the tests I don't think you have to run that often and they are all pretty quick and easy. I have heard so many people, (not on this site!) say what a lot of work pool maintenece is, but so far, ours has been a breeze. We have not had to spend much either. A couple bottles of CYA and then just jugs of bleach. Doesn't get better than easy AND cheap!
    The folks with more experience with different methods will have more to say, everyone is very helpful here, good luck!
    24 ft, 52" Patriot Vista AGP, steel wall, dished bottom, 14,300 gallons
    Hayward 1 hp pump, S180T sand filter, 2 - 2 X 20 solar heating panels, solar cover and reel, 8 gal Liquidator, TF100 test kit
    Jun 2010
    NE Ohio
    70
    I have a smallish AG (10,000 gallons) pool and do virtually nothing but add half a bag of shock approx each week and acid from time to time. I drain about 20% of the water for winter closing...(maybe less but about 4 - 6 inches below the return.) I use a few pucks to bring up my CYA when I reopen becuase it's usually low.
    I still have the same 7 lb container of dry acid from last year so that's $10.00 in acid costs for two years and minimal chlorine costs. I vacuum about once a week...less if we don't have a bunch of rain.
    My TA is kind of high but I'm at peace with that.
    My pH barely changes so things seem to be pretty stable.
    I do however test chlorine and pH every day.
    Cheap and easy...just like me
    Peter
    21' X 52" above ground
    1 HP Hayward Power Flow Matrix Pump
    Hayward EC40C DE Filter
    Guest
    Depends on where you are located. I don't spend 10 minutes a week on my pool (I have been known to test my water 5 times in a day though!), and I am extremely picky about my water. I dump a jug or 2 of chlorine in my Liquidator a week, skim a couple times a week, and brush on the weekend. By far the majority of my time is spent on brushing, and that takes all of maybe 5 minutes.
    Covers, in my opinion, do not let you enjoy the look of your pool (and we all know we are out of them way more than we are in them ), and don't let them "breath". SWCG work great in areas with low CH, which I am not blessed to have from the tap (but I can fix that ). A little chlorine added (or made) daily, check the pH (5 drops-tough!) and the chlorine (not too tough either!) a couple times a week (or daily, if you're me ) and add some Muriatic acid to bring down (or soda ash to bring up, as the case may be), brush as necessary and enjoy! Doesn't get much easier than that!
    Dec 2009
    Laguna Niguel, CA
    35
    SWCG and a PH/Acid system.
    18 x 28 with 8x8 Spa with Vanishing Edge Dam wall, Pentair 4 x 160 & 2 Whisperflo, Badu Swimjet SuperSport, Pentair 400Kbtu Minimax, 80sqft DE CAT 1000 PH Controller with Stenner Pump/Tank combo
    Jul 2008
    Arkansas
    20
    Salt Water Chlorinator is the only way to go.
    Ballparkmom
    16 x 33 x 52" AG pool, Hayward Vari-flo pump & sand filter, 1 skimmer, 1 main drain, 1 return, Zodiac LM3 24,000 SWG, Pool Rover Jr., 2 kids & a million toys
    May 2009
    Dallas, TX
    785
    That's easy! BBB...or TFP...whatever you want to call it, it is splattered all over the pages on this board! Or maybe I don't understand the question?
    I spend very little time on my pool, and everything I know about pool maintenance was gleaned from this website. All the information you need to have a truly trouble free pool is here, but you have to understand & apply it. Lucky thing is that there are countless people here who will explain it in minute detail when you have questions...
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Jul 2010
    northern California
    235
    I test chlorine and pH everyday. That is pretty easy.
    I am curous, what is a PH/Acid system?
    IG pebbletec pool: size of pool: 27,000 gal; filter: cartridge - Hayward Superstar Clear; pump size: 1.5 HP; TF 100 Test kit - got it on 7-29-10; The Pool Cleaner-4-wheel suction model; Pool calculator: http://www.poolcalculator..com/; bleach calc: http://troublefreepool.com/files/BleachCalc262.exe
    Dec 2009
    Laguna Niguel, CA
    35
    A PH/Acid system consists of a controller which continually monitors the PH during circulation, and a Acid pump/tank combination which activates to drip muriatic acid into the return line to keep the PH relatively constant. I researched most of the systems out there before choosing this one which has worked well for me. http://www.chemauto.com/products/cat1000.htm
    Guest
    Just remember, there is no "set it and forget it'. SWCG are great, but depending on your size, could ramp up your electric bill and you'll be adjusting your PH more frequently. Good luck with your decision!
