Thread: Problem installing/seating SM-20-3 spider gasket
    Mar 2008
    Lafayette, LA
    108
    I installed a new spider about 3 weeks ago. It was for a 2" sidemount Triton SM 20-3 backflush valve. There were 2 to pick from at the LPS. I chose the one that had the larger diameter center hole, which matched my old gasket.
    I cleaned all the mating surfaces super slick. I used ptfe lube to put it in. But whenever I finished installing it, the spring tensioned plunger would not depress. It was stuck in the up position, handle down and loose.
    I took it back apart and flipped the gasket over, with the sealing ridges up. It fit a bit better but once again, the plunger couldn't depress correctly once everything was tightened back up. I had very carefully torqued the flange bolts, using a star pattern as I took it down in stages. I am very certain the gasket was not out of the groove when finished.
    I thought that maybe the gasket was a bit thick so that it could compress with the spring tension over the next few days and take a seat. That never happened and when I went to backflush it the first time 3 weeks later, it tore. It was tight, but operable when I first installed it.
    Where am I going wrong?
    Is there a thinner gasket for a 2" side mount SM-20-3 valve?
    Thanks, Shell
    7x7 spa drains>16K IG, Gunite/Plaster, Compool 3600, Purex Triton Minimax Plus 350, Sand Filter, 8 Gal Liquidator
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Re: Problem installing/seating SM-20-3 spider gasket
    i know this is old, but i think the problem is the valve itself and not the gasket. I would replace the top haf of the muliport valve. Also, anytime you are installing a new gasket, it should be super glued into the track, otherwise it will pop out everytime you go to backwash.
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
