Thread: filtering time vs pressure
    Mar 2009
    Charlotte, NC
    539
    My normal filter pressure is 19-20 psi.
    When I run my Polaris cleaner, the filter pressure drops to 16psi, about a 20% drop.
    Should I increase the total pump run-time by 20% to compensate for this or is turnover not really directly related to pressure?
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: filtering time vs pressure
    I would leave it alone. I psi drop would actually indicate your getting more flow..I think
    22,553
    I agree with Dman, leave it alone. There's nothing magic about 1 turnover. It's just a starting point. Some pools take more than one turnover to remain clear and some take a little less. It's really whatever works for your pool.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Assuming nothing changed in the return side of the plumbing, a 20% drop in filter pressure is about a 11% drop in flow rate give or take. So running an extra 12% gets you back to where you were but then again, that isn't really going to make much difference anyway.
    Mark
