Results 1 to 7 of 7
Thread: What to do when you don't close the pool in the winter?
    Jul 2010
    northern California
    235
    I live in northern California where the winters can be freezing at night for a few nights and the days can be in the 50's or 60's. I did not do anything to get my pool ready for the winter during the past 2 winters. We only had the pool for 2 winters. It went down to 29 degrees for a few nights last winter. All I did was to put a piece of mil 6 plastic over the pool equipment since ice was forming. Should I be doing more than that?
    I have been reading on this forum that I should have the pump running during freezing temperatures but I didn't because I did not know. What should I do differently for the pool when the temperatures are freezing at night and I don't close it for the winter? I intend to continue to test the water. No pool cover was ever made for the pool since it is a free form pool so I can't cover it. Thanks.
    IG pebbletec pool: size of pool: 27,000 gal; filter: cartridge - Hayward Superstar Clear; pump size: 1.5 HP; TF 100 Test kit - got it on 7-29-10; The Pool Cleaner-4-wheel suction model; Pool calculator: http://www.poolcalculator.com/; bleach calc: http://troublefreepool.com/files/BleachCalc262.exe
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: What to do when you don't close the pool in the winter?
    Run the equipment with all the plumbing (skimmers, returns, water features) operating whenever it is forecast to be near or below freezing.
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    agreed, I woud just set the timer to run at night since thats when temps drop below freezing.
    If you wanted to cover it you could get one of those "beautiful " tarp covers. But if you havent covered it in the past with no issues then i wouldnt worry about it. Covering it would just keep it clean.
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    22,537
    The plumbing can stand a couple of hours if it's just below freezing but it's not worth the risk for the small amount of electricity saved.
    There are timers that have a freeze protection function built-in. It would be well worth the expense to get one and use it. That way you don't have to try and remember to turn the pump on when it's going to be below freezing.
    SW Georgia
    300
    I do not close my pool during the winter months either. I run my pump at night during the months that I could expect freezing weather.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Jul 2010
    northern California
    235
    Thanks. I will set the timer so the pump will run at night when it is forecasted to freeze. If I want to cover it again with plastic to keep the ice off the equipment, is it still ok to run the pump? There was a sheet of ice on the plastic last winter because it rained during the day or days before and then froze at night.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    An incandesant light bulb in a work light fixture can do wonders keeping things from freezing under a tarp.
    Ike
