Results 1 to 7 of 7
Thread: Pool noodles and bacteria/algae
    Alberta, Canada
    177
    Does anyone know if pool noodles can harbor bacteria and/or algae to the point it would contaminate a pool?
    I'm thinking if they are used in chlorinated water that should take care of it, but they also spend as much time out of the water sitting in the sun.
    The pool noodles we use are the big fat, solid ones, they definately take on water after a few months so I'm just curious if anyone has had an issue with that.
    Deena
    http://www.lindbrookstargazer.ca
    100,000 liter IG vinyl liner
    Rolachem Chlorine & Muratic acid Auto feeders/Pool Perfect Auto feeder
    Pentair 30" filter (Tagelus) Sand filter/Centruion switchless pump 1.5/.25 HP
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pool noodles and bacteria/algae
    I've never noticed any issues - i toss them each season cuz they start to break down.
    Alberta, Canada
    177
    Quote Originally Posted by frustratedpoolmom
    Just thinking out loud....as to my other post about algae issues and my having my pool at shock levels for several days and still losing chlorine on the overnight test. I didn't think it would be a problem and those things are expensive so I'd hate to throw them out if that is not contributing to the problem.
    That's what we do too....toss them at the end of the season. If I could just convince the kids to stop biting chunks off they might last a little longer.
    Not sure what makes them want to bite them.
    Deena
    11,969
    That is a good question isn't it.
    We recommend throwing the toys and floats etc in while shocking - just in case they are harboring anything. So if you are in doubt either toss in the pool or toss it in the garbage... LOL
    Alberta, Canada
    177
    Thanks....noodles are in the pool right now as I shock.
    Deena
    DaveNJ's Avatar
    Toms River, NJ
    520
    At the end of season I use the noodles in the railing cups, autofill, skimmer when I winterize the pool. In the spring I throw them out.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Alberta, Canada
    177
    Quote Originally Posted by DaveNJ
    That's a great idea. Thanks
    Deena
