Thread: My results after draining of water - thoughts?
    I drained a little more than 1/2 my pool, and refilled with tap water. I intend to go with liquid chlorine now, instead of Trichlor / Cal-hypo the pool guys were using.
    Just tested results:
    25000 gallon inground, vinyl-lined pool
    82 degrees (water)
    Direct sun from 8am to 4pm daily.
    CYa: 50
    TA: 90
    pH: 7.2 (LOW)
    FC: 6.5
    CC: 0
    TC: 6.5
    CH: 240
    All good except pH. I added roughly 32oz by vol of soda ash. (I say roughly because I didn't have an exact measuring tool).
    Thoughts?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: My results after draining of water - thoughts?
    Looks swimmable.
    I wouldn't have added soda ash - TA is high enough that some aeration would fix pH.
    Bookmark Pool Calculator. Set it up using your specs. Be sure to indicate recommended levels from TFP. It will guide you.
    Do you think I'll now end up with too HIGH of a pH?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Quote Originally Posted by sws1
    Probably not but if you do it will be easy to fix. Aeration would just be a means to raise the pH without adding chemicals.
    Love TFP? Become a
    TFP Supporter!
