Thread: AquaLogic P4 vs PS4
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    AquaLogic P4 vs PS4
    Anybody can tell me what is the differences between the P4 and the PS4 (appart from the price)?
    14X24 ig vinyl pool 3ft-4 1/2ft deep - 7000 gal
    Aqua Genie skimmer and return - no main drain, 1 hp hayward pump, 27" Hayward filter with Zeobrite,
    Aqua Logic P4 controller + SWG, 2 lights
    192 square feet of solar panels controlled by P4, 5KW electric heater (just in case...)
    Jun 2007
    SF Bay Area
    441
    Hello el_steak,
    I am in the middle of installing my Aqualogic PS4.
    The main difference is in the number of outputs
    P4 - 4 relays, 3 valves outputs, 1 heater control, 3 temperature inputs
    PS4 - 4 relays, 4 valve outputs, 2 heater controls, 3 temperature inputs
    http://www.poolwarehouse.com/Aqua-Logic ... trols.html
    The PS4 unit uses the same internal relay for both Valve 4 and Heater 2 - you can't use both at the same time. I am not familiar with the P4 main circuit board, but at least on the PS4 main circuit board, if you don't need a Valve 4/heater 2, there is a fairly inexpensive way to use this 28 Volt AC output to control a fifth relay.
    Also, the local display and remote displays are different between the P4 and PS4
    P4 - http://www.haywardnet.com/products/Manu ... ual196.pdf
    PS4 - http://www.haywardnet.com/products/Manu ... ual200.pdf
    Either the P4 or the PS4 is able to deal with Pool Only, Spa Only, or Pool/Spa combinations. However, P4 can only handle Pool/Spa combinations where the Pool/Spa equipment (filter pump, etc) is shared. The PS4 is a little more advanced where it can handle Pool/Spa combinations where there is separate (dual) equipment for both the pool and spa.
    Also, it appears that the PS4 can do "Group" functions, which seems to be AquaLogic's term for a macro function. The P4 doesn't appear to have a "Group" function.
    Remember that a base P4 (or PS4) still needs valve actuators (GoldLine GVA-24 or equivalent Jandy or Pentair). Also, the base units do not come with remote displays and/or floating (and waterproof!!) wireless spa remotes.
    The best prices I have found (except for my lucky Leslie's Pool purchase) is $629 for a PS4, $79 for GVA-24 valve actuators, $165 for wireless spaside remote, and $269 for wireless table top remote at www.aquapoolstore.com. The best price is $115 for the wireless base unit is at www.h20poolproducts.com, alothough the first store is not far behind for this piece at $119. CAVEAT: I have never done business with either store, and I didn't have the time to compare shipping charges in this price search/comparison.
    I hope this helps.
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    Thanks Titanium, thats a pretty thorough explanation.
    I only have to control a pool filter pump, a solar panel 3-way valve, some lights and the chlorinator. No spa, and no "water features".
    The P4 would probably be good enough for me then. I'm in Canada and to avoid being ripped off with duty "brokerage" fees (UPS, FedEx, etc), I generally try to buy my stuff from Canadian dealers. Unfortunately there's not a lot of Canadian online pool stores, but I did find one that lists the P4 @605$ cdn and the PS-4 @825$ cdn (shipping included). That's a bit more than what you are quoting, but still way less than the local pool equipment store.
    Thanks for taking the time to answer my post.
    BTW, I've also read through the whole P4 installation and operations manuals. My GF thinks I'm a freak
    Jun 2007
    SF Bay Area
    441
    el_steak,
    The P4 does sound like a good match for your installation, especially if the fancier local panel and the "group" (macro) function do not interest you.
    Except for the chlorinator, you could get by with an old-fashioned Intermatic mechanical timer and a GoldLine Gl-35 solar controller for your installation.
    My reasons for upgrading from my existing 23 year-old Intermatic mechanical timer and 8 year old GoldLine solar controller were as follows:
    1. The metal case of the Intermatic mechanical timer was all rusted and needed to be replaced.
    2. I wanted the remote control features that automation would bring. I got tired of getting out of the nice warm spa in the middle of winter in order to adjust the return and suction valves, and to fiddle with the spa temperature setting.
    Titanium
    P.S. Regarding the GF thinking you are a freak: tell her you feel the same way when she goes out shopping for shoes.
