Results 1 to 8 of 8
Thread: Handy leveling tool for building a AGP
    I had a lot of ups and downs this summer building our first AGP. One thing that was well worth the money I spent was a water level. Some prefer a laser, but that wasn't in my budget and things were drawn out too long to rent one. I could have bougth 3 of them for what the rental store wanted for as long as I needed it! You can make your own homemade water level, but for $40 or so you can get this fancy one online. Very accurate and easy to use, don't know what I would have done without it, highly recommended. You can check it out at: http://www.watrlevel.com.
    [attachment=0:3aj1u5s8]24in_catalog%20001%20wide_small.jpg[/attachment:3aj1u5s8]
    I am in no way affiliated with the company, but it's a really slick idea. Just thought I would throw it out there for folks to check out. We are now happily swimming in our crystal clear TFP!
    24 ft, 52" Patriot Vista AGP, steel wall, dished bottom, 14,300 gallons
    Hayward 1 hp pump, S180T sand filter, 2 - 2 X 20 solar heating panels, solar cover and reel, 8 gal Liquidator, TF100 test kit
    SW Georgia
    300
    Re: Handy leveling tool for building a AGP
    I used one when I built my inground pool and it worked well. Mine had an automatic feature which allowed it to be operated by one person which was great since I was normally by my self.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Very cool, I think I'll be buying one of those for this summers install.
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    OMG, what a simple solution to a complex problem! So glad I searched TFP for guidance
    Intex Rectangular AG Ultra Frame Pool Set, 24' x 12' x 52" (8403 gal, well water)
    Intex Krystal Clear Saltwater System model number: 28663EG/54601EG
    Intex sand filter pump, 120V 1,600gph with GFCI
    Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer
    Jun 2015
    Stockholm, Sweden
    250
    Here is my DIY version: two car jack stands, a garden hose, two plastic tubes with metric scales on them and of course silver tape! Allowed me to singlehandedly level pavers for a 12x24 Intex within a few milimeters.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    There are many Elevation/altimeter app's available for iOS & android, some look like they go down to 2 decimals of meters/feet.
    I wonder if one of them would do the job and it would be interesting if one of you that have a water level would compare the level to an app?
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jun 2015
    Stockholm, Sweden
    250
    Most altimeter apps I have seen are only accurate +/- 5-10 meters/feet, i.e. not applicable for precision measurement. Do you have a suggestion for an app to test?
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by Mickelin View Post
    I have used 'My Altitude & Altitude+-BUT have never needed/wanted accuracy down to inches so I cant say if they're accurate enough. t
