Thread: Return jet
    Return jet
    My pool is missing a return jet in an area were it is right above a step. problem is the step is so high a normal jet will not go in as the side hits the step. Does anyone make a thin jet that is the same diameter as the hole? My pool store guy has been looking and cant find one, Its bugging the heck out of me not having a jet in that hole.
    22,543
    Re: Return jet
    Have you looked at press in eyeball fittings? They may be smaller than standard fittings.
    Re: Return jet
    No I have not seen them. Do you have a link by any chance? Thanks.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Re: Return jet
    I'm not sure about in the US but here in Europe, Astralpool make a return that fits inside a 50mm pipe.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
