Results 1 to 9 of 9
Thread: Hardened algae on intex liner
    May 2008
    gulf coast of Texas
    166
    We seem to have hardened algae(green) around the bottom edges of the liner. I have brushed it over and over and it just doesn't come loose. I rubbed it with my foot and it feels hardened..like rough and like it calcified to the liner? Can that happen if you don't brush it when it forms? We were lazy with the pool this summer since no one was really using it. The water is clear, I just can't scrub the algae off.
    Julie
    Atlantic Pool Products "Prestige" metal wall pool 18' x 48" round
    vinyl liner
    Hayward Power Flo pump
    Hayward Perflex DE Filter Model EC50AC
    22,550
    Re: Hardened algae on intex liner
    Doesn't sound like algae to me. Can you provide us a full set of test results?
    pH
    FC
    CC
    TA
    CH
    CYA
    Jul 2009
    London and France
    574
    Sounds more like copper carbonate.
    http://en.wikipedia.org/wiki/Malachite
    May 2008
    gulf coast of Texas
    166
    Okay, I was finally able to get out there today to get some numbers for you. There are a few leaves on the bottom of the pool that I need to scoop out this evening that fell today. here are my numbers:
    FC 3
    CC .5
    TC 3.5
    pH 7.5
    TA 160
    CA 380
    CYA 55
    And here is a pic I got with my phone while getting the numbers.
    Julie
    vinyl liner
    May 2008
    gulf coast of Texas
    166
    Julie
    vinyl liner
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Looks like stained calcium scale to me.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    ya, i'm thinking MITS might be right. Has your PH been above 7.8 for any extended periods?
    May 2008
    gulf coast of Texas
    166
    Honestly, I don't know if the pH was up to 7.8 or higher for an extended time. I didn't test it the whole month of July. I know...my bad.
    If I lower the pH for an extended period, would it loosen it or dissolve it?
    Julie
    vinyl liner
    30,421
    Perhaps, but I would elevate the chlorine levels first. Keep your FC up around 10ppm or so for a week and see what effect that has. ANY chance you get, scrub the stain trying to loosen just part of it.
    If that fails or you see no improvement after a week or so, then you can consider pH but that's a little trickier and you'll have to test carefully.
