Results 1 to 10 of 10
Thread: pH keeps dropping
    Aug 2010
    Akron, Ohio
    11
    pH keeps dropping
    Ok here's a question hopefully someone can help with. I don't know if I have a problem or not.
    I recently found this site and began using borax to raise pH, since I found it was low with my new drop test kit.
    I have added a total of 4 boxes of borax over the last 2 weeks. I added 1 and pH came up to 7.0, so I added another and it went to 7.4. A couple days later the pH went to 7.2, so I added another box and it went back to 7.4. After another couple days it was 7.0, so in went another box.
    Do I have a problem or is this normal. removed my Nature2 cartridge a couple days ago and am adding 12.5% bleach for chlorine.
    I appreciate any help.
    Thanks!
    17000 gallons = 27" round
    Filter = cartridge
    AG (above ground)
    Hayward 1.5HP dual speed pump
    Dec 2009
    Central Massachusetts
    2,690
    Re: pH keeps dropping
    Can you post a full set or water test numbers?
    FC
    CC
    TA
    CYA
    CH
    Sounds like the TA might be low, but we really need to see some numbers first before any advise can be given. How have you been chlorinating all season?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    22,550
    As BK says, we need to see some numbers. If your TA is low it'll drive your pH down BUT, we need to see all the numbers before we start making assumptions as to what's going on.
    Aug 2010
    Akron, Ohio
    11
    Ok, I'll run my tests and post later tonight. Hopefully we can get an idea of what's up.
    Thanks!
    Filter = cartridge
    AG (above ground)
    Aug 2010
    Akron, Ohio
    11
    Here are my results as of this evening:
    pH = 7.4
    FC = 2
    TA = 90
    CH = 240
    CYA = about 15....Just added 4 lbs a couple days ago. How long should I wait to get an accurate reading?
    Any ideas?
    Filter = cartridge
    AG (above ground)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Are you keeping the pool covered alot? With a TA at that level and using a solar cover, it's not uncommon to see the PH drift down. Adding CYA will also lower it a little bit.
    Aug 2010
    Akron, Ohio
    11
    The cover is on every night. If it is used during the day the cover does not go back on until the evening usually. Where should TA be? Should I just continue with the borax?
    Filter = cartridge
    AG (above ground)
    30,421
    It sounds to me like your pH will stabilize from here on out. I think it took you two additions to get it where you wanted (not uncommon) and then you needed one more to compensate for the addition of CYA.
    Please do not worry about TA. Simply monitor your pH and add borax as needed to maintain where you are. I think you are fine and your adjustments are about complete.
    PS - if pH swings by .2 or so, leave it alone. Do not lower it until it reaches 7.8.
    Aug 2010
    Akron, Ohio
    11
    Ok I'll monitor for a couple days and see what is happening. Thanks for all the help.
    BTW, I rigged up a pump / timer to feed bleach each evening and it is working great thus far. If I get the opportunity to snap some pics I will post.
    Thanks again all!
    Filter = cartridge
    AG (above ground)
    Aug 2010
    Akron, Ohio
    11
    The pH has leveled at 7.4 as duraleigh said. The pool looks better than ever.
    Thanks for the help!
    Filter = cartridge
    AG (above ground)
