Thread: Are multiports and filters manufacturer-matched?
    ajgiii's Avatar
    May 2008
    North Virginia
    26
    Hey All
    Is it better to have a multiport and filter made by the same manufacturer?
    In my situation, I've an American Products filter with what was originally an Amer. Prod. multiport. The top of the multiport is now Pentair, but I'm replacing the whole thing and am wondering if I should get the Amer. Prod. multiport.
    Fittings aren't an issue because you can get the multiport w/o fittings.
    Thank you.
    AJGIII
    30K gallon, inground w/integral spa, blue/gray plaster; Pentair Intelliflo pump, D.E. filter, Ultraflow UV generator, Hayward tab chlorinator, Polaris 360, Raypak propane
    "As long as you are in the seat...Make a Difference"
    ---Captain James T. Kirk, circa 2293
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Are multiports and filters manufacturer-matched?
    Pentair is American Products.
    The only difference is that multi-ports designed to go with the filter will have the exact same pipe spacing and often have unions that match the fittings on the filter, so they are easier to install. Once installed it doesn't make any difference.
    ajgiii's Avatar
    May 2008
    North Virginia
    26
    Thank you.
    John T. I thought the same, that Pentair was American Products (especially since the website I was ordering from listed the names under the Pentair brand) and I ordered a Pentair, pre-plumbed multiport. Unfortunately, it doesn't match up to my American Products Titan II filter connections. It took some research, but I found the fittings I need....but have to return the multiport anyway because I don't feel comfortable altering a smooth-bend (PVC) pipe. Hence my Q.
    Thank you very much.
    AJGIII
