Thread: is it time to replace my SC-60 salt cell?
    Like others, I have had pretty good operation of my unit for the last several years. I have been using this cell for over 3 years now, maintaining a FC level of approx 5 throughout the usage time. However, I have noticed lower FC levels recently, wondering if the cell is near end of life. It still can produce chlorine- bubbles obviously generated when I hit 24 hr boost.
    I've done some preliminary troubleshooting:
    Cell is clean, evidence of wear on the outer plates
    Salt level =3800, calibrated
    water Temp = 80 degrees
    water chemistry unchanged, parameters all ok except lower FC levels than normal FC now around 1.0 instead of the normal 5.
    after hitting boost, then test pool pilot, i get the following info:
    Amp hours =9120
    Voltage = 28
    time to replace cell?
    Amps =6.5
    17,500g, IG pool/spa, pebblesheen, Autopilot TC SWG, Pentair 4x160 variable speed pump. Sta-rite cartridge filter, Sta-rite Gas heater, Polaris 280 cleaner
    22,549
    Re: is it time to replace my SC-60 salt cell?
    Your amp-hours are approaching 10,000 so it's probably getting close to time for a replacement.
    Have you done an OCLT (overnight chlorine loss test) just to make sure something isn't in there?
    Also, it'd be nice to see a full set of test results.
    That is an amp-hour reading, not an hour reading. The cell is rated for about 10,000 hours at 5 to 8 amps, so cell lifetime is typically somewhere around 50,000 to 80,000 amp-hours. Remember that actual cell lifetime is somewhat variable from unit to unit.
    You need both amps and volts, read after the cell has been on for a couple of minutes, to judge if the cell might be getting old. Towards the end of the cell lifetime, the chlorine production will fall for a while before the cell fails.
    Reduced FC levels are almost always caused by some chemical imbalance, not a cell problem. You should post a full set of water test results.
