Results 1 to 10 of 10
Thread: Shelf Life for Liquid Chlorine
    Hi,
    Does anyone know what the shelf life is for liquid chlorine? Occasionally, Leslie's runs a sale on chlorine. Refill 2 jugs and get 1 for free. Instead of having the chlorine sitting inside my house go to waste, I rather pour it into the pool. Thanks.
    Bleach shelf life depends on the concentration and the storage temperature. 6% bleach will keep for a year or two at under 80 degrees. 12% bleach will keep for a couple of months at under 80 degrees. As the temperature goes up the storage time goes down dramatically.
    If you are getting 10% or 12% on sale one option is to dilute it one to one with water and store that.
    Mar 2007
    San Rafael, CA USA
    12,082
    The table at the bottom of this link gives some half-life numbers for chlorine at various concentrations and storage temperatures. The half-life is how long it takes for the chlorine to lose half of its strength. Most of the strength is lost earlier on as this is a non-linear process (it's an exponential decay whose rate is faster at higher concentrations).
    I use 12.5% chlorinating liquid and find that it keeps nearly all of its strength over a month, but the storage temperature is from 60 (night) - 80 (day) degrees, typically.
    Jason's suggestion of diluting the chlorinating liquid for longer-term storage is, of course, excellent. Just be sure to dilute with relatively pure water that does not contain metals. So most city water is OK, but well water is most likely not and could accelerate degradation (metals act as catalysts to speed up the degradation process).
    Arizona
    924
    Something I have noticed and I would think would surely affect this is that the off brands usually have a seal you must peel off, under the cap - which I'd think is a good idea. While the Chlorox brand does not have this type of seal. The bottles I purchase of 12% fresh chlorine don't have it either and they told me, at the store I purchase them from that I shouldn't stock up on them because they can lose quite a bit of potency in a couple of weeks. Of course the temperature here is in the 100's this time of year, too.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Shelf Life for Liquid Chlorine
    Quote Originally Posted by rainman168
    Hi,
    What makes you think I don't want it?
    The above advice is great, just keep it at a fairly ~ neutral temp and out of direct UV exposure
    Luv& Luk
    -Ted
    Aug 2007
    Hemet, California
    9
    Does anyone know if this works -- has it been tested?
    Quote Originally Posted by chem geek
    The table that chem geek references shows that at a given storage temperature the half-life of bleach is a function of the
    manufactured concentration. For example, at 80oF 10% (trade %) bleach has a half-life of 241 days while 5% bleach has a half-life of 735 days. If I buy 10% bleach and store it for 241 days it will have a chlorine concentration of 5%. But it will not be the same as bleach manufactured at 5% -- it will still have a half-life of only 241 days. I don't know what causes the difference (maybe accumulated chlorates or different amounts of metal ions introduced in the manufacturing process or something else). In any case, I can have two bottles of bleach with the same concentration of available chlorine but with two very different half-life's.
    I can't deduce from this information what the half-life would be if I were to dilute 10% bleach to 5%.
    Diluting bleach is not a fun job and I don't think I'd be willing to do it without more evidence that I'd be gaining half-life.
    So, is there more information available? Or has someone on this forum actually done this and measured the results?
    Brand new (June 1, 2007) in-ground pool.
    Pebblesheen over gunnite 12,500 gallons.
    First pool ever. DE filter.
    Attached spa with spillover into pool.
    Semi-desert climate : no leaves, high evaporation.
    Very light bather load.
    New Brunswick Canada
    819
    I know most bleaches come without a sealed top,would them having a sealed top effect the shelf life?
    It is very imporant that you don't add any metals to your bleach. It wouldn't be a good idea to dilute bleach with well water high in metals.
    Mar 2007
    San Rafael, CA USA
    12,082
    It's more the other way around. If well sealed, the bleach will not have additional loss from exposure to air and mostly from outgassing.
    The bleach (in the discussions in previous posts) degrades because it is concentrated, not because it is escaping. It's just a natural chemical reaction since chlorine is by its vary nature unstable -- that's what makes it react with many chemicals and gives it its power to oxidize and to kill pathogens. So not only does sunlight breakdown chlorine, but chlorine can react with itself to break itself down and this is what happens fast enough to notice when the chlorine is more concentrated. It's also why the rate of breakdown varies roughly with the square of the concentration so that 12.5% chlorinating liquid breaks down about 4 times faster than 6% bleach.
    Higher temperatures accelerate all chemical reactions so increase the rate of breakdown of chlorine as well.
    Richard
    Apr 2017
    Houston
    161
    What would be the expected shelf life for 10-12% @ 110*F. I could shade the container and bring it down to 95* but IDK. I'm thinking about a peristaltic setup, and I estimate my chlorine demand at or around 15 gal/mo.
    Here in Houston, lately, it's been mid-high 90s w heat index of 100s.
    45,000 gallon (18x49) in ground plaster in Houston. [Gallery]
    2HP Hayward Northstar Pump, Hayward DE 6020 (60sqft) filter, Pentair MasterTemp 400k BTU heater, Pentair SuperFlo 1HP -340038 water feature/fountain pump
    Pentair Easy Touch 8 w wireless remote, Hayward TigerShark QC, & Taylor 2006c
