Results 1 to 15 of 15
Thread: AGP POOL COOLER
    Jul 2009
    Pearland, Texas
    24
    AGP POOL COOLER
    Anyone using a successful way to cool pool water? We have a 12 x 24 AGP, partially buried. The water this summer in Texas has been like a bath tub at times. Anyone familiar with the pool cooler misting device or any other way that works well? Thanks!
    AGP partially buried since 2009, with surrounding wood deck and flower bed. 12 x 24 oval x 48" deep Celebration by Forum. Steel sides, vinyl liner, Barracuda pool cleaner. Pentair 1.5 HP single speed sand pump. Flower fountain - works well to cool water up to 10 degrees.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: AGP POOL COOLER
    Some people have had success running a pool fountain at night to promote evaporative cooling. The higher and finer the spray the more cooling you will achieve. Also just standing under the spray from the fountain feels much cooler!
    Love TFP? Become a
    TFP Supporter!
    22,553
    Re: AGP POOL COOLER
    Zea's suggestion is by far the less expensive way to go but running a solar system at night is the best way without costing to run a cooler.
    Jul 2008
    Arkansas
    20
    Re: AGP POOL COOLER
    I have friends who have taken buckets of water and frozen them to bring the temp down. My Oak trees have grown so much in the last two years that the pool is shaded from 3 pm till the next morning and although the temp of the pool still rises, it is much more comfortable. For long range planning you might try that.
    Ballparkmom
    16 x 33 x 52" AG pool, Hayward Vari-flo pump & sand filter, 1 skimmer, 1 main drain, 1 return, Zodiac LM3 24,000 SWG, Pool Rover Jr., 2 kids & a million toys
    Jul 2009
    Pearland, Texas
    24
    Re: AGP POOL COOLER
    We bought a fountain last year and it works amazingly well to cool water temperature! No more bath tub temp. Became cool and refreshing again. Cooled it as much as 10 degrees. Fantastic!!!
    Jun 2010
    San Antonio
    424
    Re: AGP POOL COOLER
    TXJM, What fountain did you buy?
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    30,432
    Re: AGP POOL COOLER
    I have posted this a few times here on the forum. It's Cheap! It works! It actually has some entertainment value! Importantly, it's based on rock solid science but has enough redneck character about it to impress ALL my friends
    Mine was free (and yes, I shoulda' used stainless screws) because I had some scraps of pipe but in no case should it cost more than $10-15 if you know how to mess with PVC.
    [attachment=2:1qls2qs2]cooler_det1.jpg[/attachment:1qls2qs2][attachment=0:1qls2qs2]cooler_spray.jpg[/attachment:1qls2qs2][attachment=1:1qls2qs2]cooler_det2.jpg[/attachment:1qls2qs2]
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: AGP POOL COOLER
    Duraleigh, how are you attaching to your return? Any close-up photos? Thanks
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    30,432
    Re: AGP POOL COOLER
    Sorry, Max, I intended to post that info and got in a hurry. For my pool, it was easiest to attach it to the return. I removed the internal threaded fitting and then screwed in a 1.5" piece of pvc about 7 inches long.
    Next, to keep from having to "screw in" this rather ungainly apparatus, I simply take a rubber mallet and tap the end of the T in to the 1.5" piece that protudes from the end. It has worked it's way loose a time or two but, surprisingly, it stays on pretty well.
    There's probably more clever ways of doing the same thing but the real point is that evaporation flat out works. This free device has kept my pool at an acceptable temp the last three years.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: AGP POOL COOLER
    Thanks Duraleigh!
    Apr 2011
    Brookeland, Texas
    89
    Re: AGP POOL COOLER
    You could just put a union in between it so you could attach it with out having to turn the whole thing to screw it on.
    I have a couple of questions:
    1. How long do you run it and how much does it cool the temp?
    2. Does this fountain create much aeration that your PH rises too much?
    12k gal. Free form 14' x 28' IG gunite, 8' raised spa, Hayward T15 SWG, Hayward Ecostar VS pump, Hayward Super II pump, Booster pump, Polaris 280, Hayward DE 7220 filter, 400k Btu heater, Color logic LED lights. Pro Logic controller with remote.
    30,432
    Re: AGP POOL COOLER
    Approx 8 hours daily...whenever the pump is on anyway. It varies but I would say I can usually hold the pool 6 degrees colder than it would normally be. Perhaps only 4 degrees on the 100+ days
    No, I keep my pH a little higher than average (7.6-7.8) so the aeration has very little affect on pH.
    Jul 2009
    Pearland, Texas
    24
    Re: AGP POOL COOLER
    Txmat - so sorry to see your question 2 years later. We installed a simple flower head fountain. It can shoot water up about 10 feet high. You can leave it like that to cool faster, and adjust it how you want when you are in or out of the pool, as low as a few inches. The little thing works great!
    Jun 2010
    San Antonio
    424
    Re: AGP POOL COOLER
    Thanks TXJM, as the old saying 'Better late than never." Are you talking about the kind that floats in the middle of the pool and attaches by way of a hose or the one that attaches directly to the return? I made a pvc cooler similar to duraleigh's, but found the weight was bending the side of my pool. Perhaps I used too big of PVC pipe.
    Larry in Texas
    Jul 2009
    Pearland, Texas
    24
    Re: AGP POOL COOLER
    Txmat: We use the flower fountain that attaches directly to the return.
