Thread: Painting question
    Painting question
    Hello,
    Does anyone know of a second coat of Acrylic paint is still recommended if new primer has already been applied to bare plaster? I was thinking maybe I can skip the second coat of paint to save some money. Any advice will be greatly appreciated, Thanks!
    Primed used: http://www.lesliespool.com/browse/Home/ ... 00/I/26649
    Paint to be used: http://www.lesliespool.com/browse/Home/ ... 00/I/26650
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: Painting question
    Painting a plaster pool is a short term solution to a long term problem. If you are painting to eek a few more years out of a worn out plaster finish then I wouldn't skip any steps. You won't be saving anything if you have to do it all again next season.
    Love TFP? Become a
    TFP Supporter!
    Looks like you are supposed to be using the epoxy paint if you use the primer, just an FYI. And only 1 coat is needed.
    Intex 16' x 48" Ultra Frame pool, Original cartridge filter that came with pool, Vinyl,
