I received my K-2006 test kit and I have run 2 tests. If I'm doing this right my CH and CYA are very high. For comparison The first det of numbers is from July 30 done by the pool store. After reading this forum and the pool school and considering my test results I'm rapidly losing confidence in their readings.
7/30/10
FC 10.0 (I think this is the upper limit of the pool store test, if so this was probably higher)
TC 10.0
CC 0.0
pH 7.5
Hardness 310
Alkalinity(w/stabilizer correction) 99
CYA 70
Copper 0.21
Iron 0
TDS 1400
8/13/10 8pm
FC .6 oops: )
CC .4 (I'm not very confident of this number)
pH 7.6
Total Alkalinity 160 (does the k-2006 adjust for stabilizer?)
Calcium Hardness 525 by the .5 method
CYA best guess 180-200, this was well below the 100 mark on the tube
SI ~.7
added about 90 ounces of 6.15% bleach,
8/14/10 730pm
FC 2.0 oops: )
CC .2 (I'm not very confident of this number)
pH 7.6
Calcium Hardness 600 by the .5 method
SI ~.7
After adding a 182 oz jug of 6% bleach and retesting around midnight
FC 5.5
CC 2 (not sure of this number, light was terrible and I'm a bit color blind in the red spectrum and my wife was asleep )
I could use some advice on what FC level I should target with these numbers. I know I'm low now and that I may need to shock. The pool calculator suggest 14-21. I still don't completely understand the relationship of CYA/FC, my understanding is that I need an FC of 10% of the CYA level and that that is safe to go in. The water is clear and looks pretty good. I have noticed when I brush there is a layer of white on the bottom that clouds up when disturbed, not real thick though.
The CH test gave me the fading result so the last test I used the alternate method which seem to work a little better. Also I plugged the FC numbers in to the pool calculator from the midnight test and the FC numbers don't agree for my pool size, 25000 gal. The previous owner said that was the size, I'm going to measure and confirm as best I can, it's a freeform design. If I plug in 18000 gal the poll calculator is right on with my FC numbers.
Any thoughts are appreciated, thanks.
7/30/10
TC 10.0
CC 0.0
pH 7.5
Hardness 310
CYA 70
Copper 0.21
Iron 0
TDS 1400
8/13/10 8pm
FC .6 oops: )
pH 7.6
SI ~.7
8/14/10 730pm
FC 2.0 oops: )
pH 7.6
SI ~.7
FC 5.5
