Thread: Testing bromine level with TF100
    I think I read that you can use the TF100 FC test for bromine as well and the conversion ratio is 2.3 (or 2.25 or 2.5) x FC = bromine ppm (but I can't find the posts now). So I should multiply the number of drops by 0.5x2.3 to get the bromine level? Is this correct?
    If so then I should plan to maintain bromine at 4-6 ppm level using this test if using the 3-step process?
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Testing bromine level with TF100
    Yes you can, and the conversion factor is 2.25. FC x 2.25 = bromine ppm in bromine sanitized water.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
