Thread: What does broadcast mean
    Jul 2010
    Montreal, Canada
    49
    I need to lower the PH in my pool, the instructions say to broadcast the acid
    what does that mean?
    18 feet AGP
    SWG
    Catridge
    22,553
    Re: What does broadcast mean
    Broadcast means to spread it around the pool in a random pattern.
    What type acid are you using?
    If it's liquid just pour it slowly in front of a running return. If it's dry acid mix it in a bucket of pool water and pour it slowly in front of a return.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,652
    Wear eye protection or be dang careful too! Avoid breathing the fumes too.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    I don't know if the techniques are valid, I guess we will have to prove them on Myth Busters but I heard that there are two techniques to pouring acid. The first is to pour it in a slug, all at once in the same spot. This is supposed to reduce pH plus TA. The second technique is to broadcast. This technique is to basically throw the acid out into the pool, kind of like tossing a baseball, and this will lower just the pH and not so much the TA.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by benavidescj
    ...The first is to pour it in a slug, all at once in the same spot. This is supposed to reduce pH plus TA....
    This is a myth. No busting necessary.
    pool-school/lowering%20total%20alkalinity.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by svenpup
    Yup...acid reduces both PH and TA regardless of how you add it. The slug method can actually cause damage to your pool surface.
    Funny when I read the broadcast question, I was thinking get a loudspeaker and announce to your neighborhood that you are handling acid
