Thread: Does liquid chlorine add salt?
    Apr 2009
    Burlington, ON, Canada
    344
    If I manually shock my pool with liquid chlorine (the bottle says sodium *something* (hypochlorite?) on it) will this raise my salt level as well. I'm assuming yes, since it's 'sodium', but just wanted to make sure.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Does liquid chlorine add salt?
    Adding any form of chlorine adds salt. There are many threads about this including this one: bleach-adds-salt-t6836.html
    The amount of salt that is added is usually irrelevant and can be ignored.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Yes. To find out how much you can check http://www.poolcalculator.com/. Enter your gallons and look near the bottom where is says "Effects of adding chemicals."
    18'x48" Intex metal frame pool, 1600 Intex sand filer/pump combo, Intex SWCG.
