Thread: Ascorbic acid - how long will it consume chlorine..
    Apr 2009
    Burlington, ON, Canada
    344
    If I'm not mistaken, an AA treatment will also use up chlorine. How long will this continue, and can I speed up the process by shocking the pool (if I add more chlorine, will it get rid of the excess AA, now that the stains are gone?)
    Thanks.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Ascorbic acid - how long will it consume chlorine..
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Mar 2007
    San Rafael, CA USA
    12,082
    In particular in this post in that thread I give an amount of chlorine needed to get rid of the ascorbic acid. The reaction is fairly fast so it's not necessary to go to shock levels.
    Apr 2009
    344
    Thanks. Lots of good information in both links. Should probably have searched first...
