Results 1 to 7 of 7
Thread: TEST RESULTS
    TEST RESULTS
    Temp 88
    FC 10
    CC 0
    TC 10
    pH 7.4
    T/A 130
    CH 320
    CYA 35
    THANKS FOR THE HELP!
    LeAnne
    Pool Size - 6000 gallons
    Filter - Cartridge
    Above Ground Pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Re: TEST RESULTS
    You got those numbers just by lurking here? Wow.
    Welcome!
    22,553
    Re: TEST RESULTS
    Good job! and welcome to TFP!
    You can let your FC come down to about 4-7ppm.
    What does your water look like?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: TEST RESULTS
    Leanne welcome to TFP, but I must ask, is this a duplicate id?
    Your post seems awfully like Gerri's
    test-results-t25073-20.html
    If so, having a duplicate account is against our forum rules.
    Re: TEST RESULTS
    She is my sister. Am I allowed to post
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: TEST RESULTS
    You're fine. Welcome!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: TEST RESULTS
    Welcome, you are fine, but we like to avoid the same question being asked multiple times, concerning the same pool, in different threads. Just helps us make sure we have you're history in one spot vs random posts in multiple threads. If you would both like to post, that is fine, but if it is related to the same issue, just keep it in the same thread, instead of starting a new one.
    Here is the thread your sister Gerri started, with the same exact title...it just threw me for a loop when I saw the same test results to boot
    test-results-t25073.html
