Results 1 to 8 of 8
Thread: Is there a difference between cya and isocya?
    Jul 2010
    Montreal, Canada
    49
    And is there a difference in the way its applied in the pool?
    18 feet AGP
    SWG
    Catridge
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Is there a difference between cya and isocya?
    It appears to be the same stuff http://www.commonchemistry.org/Chemi...x?ref=108-80-5
    You can find what you need at the pool store, possibly at a big box store with a pool aisle, even some home improvement stores if they have a pool section. They may call it stabilizer or conditioner. You want the highest percentage of cyanuric acid possible.
    Jul 2010
    Montreal, Canada
    49
    if it's a fine powder, should I still use the sock method to introduce in the pool? or can I mix with water the put in pool, or can I simply just spread around the pool evenly?
    18 feet AGP
    SWG
    Catridge
    22,550
    Still put it in the sock, or since you have a cartridge filter and if you're sure you won't need to clean it for at least a week, you can pour it slowly into the skimmer.
    Jul 2010
    Montreal, Canada
    49
    if I poor it into the skimmer, how long do you think it will take till it disolves or takes effect?
    18 feet AGP
    SWG
    Catridge
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Either way you add it you should assume it is effective within 24hrs, but will not be able to confirm the level via testing for one week.
    Jul 2010
    Montreal, Canada
    49
    would I be able to test the chlorine levels after 24 hours or does that take a week as well
    18 feet AGP
    SWG
    Catridge
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Chlorine can be tested as soon as it's mixed into the water.
