Thread: Pool Heater Gas Line Question
    Is it normal / ok for the gas line elbows to rust?
    I've had heater replaced and tech installed new, I assume, cast iron elbows as part of the gas feed. The previous elbows were not rusted so must have been a galvanised version. The new ones are covered in rust. Will it stay on the surface?
    Thanks
    Plaster In Ground, with Waterfall Spa. Raypak Heater, Nautilus DE Filter DNS48. Built about 2000.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Pool Heater Gas Line Question
    It's normal for some gas line to rust, you can paint it if you want it to look better.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Aug 2009
    SW Wisconsin
    518
    yep...black pipe, and elbows and any other joints will rust quickly on the surface..other than your brass valves. It's normal and nothing to worry about...like Kevin said..if you don't like it...you can prime and paint it
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Thanks folks, much appreciated.
    Regards
