Thread: 2007 8110
    2007 8110
    Bought on Craigslist an intex 8110 pump. The green light never comes on. By what I've read on here if I see bubbles at the return about 10 minutes later my 8110 is working right? Water been clear for 2 months now, THX
    16' X 48" Ultra Metal Frame 1500 gallon pump
    Feb 2008
    Denton, TX
    5,061
    Re: 2007 8110
    Welcome to TFP!
    The 8110 is a salt water chlorine generator and typically, if you see little bubbles coming from the return, this is an indication that your cell is generating chlorine.
    IF your water has been clear for two months, it would stand to reason that you have FC in there. Unless you have been adding your chlorine from another source, that would tell me that your 8110 is generating it. Do you have any test results for us?
    Re: 2007 8110
    Wal-mart 6 way hth strips very hard to read accurately. Put 2 gallons of bleach 3 days apart at first fill. Tf100 is on the way. The pool is 16x48 approx 5060 gallons. Bought whole set-up on Craigs for 200.00. Can you use the BBB method with a swg, to tweak things? So far no algae or anything, water very clear.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: 2007 8110
    using a swg is BBB...actually it's SWGBB...the SWG produces chlorine hence it reduces the need to add chlorine using bleach, which is the 1st B in BBB.
