Thread: Leak in Pentair FNS Plus DE filter. Any advice?
    Hi All,
    My 5 year old Pentair filter has started to leak between the top lid and bottom base. I tried tightening the clamp but no luck. Any ideas on a fix or do I just need to replace the gigantic O-ring?
    Thanks!
    Joe
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Leak in Pentair FNS Plus DE filter. Any advice?
    I guess the big question is: has anyone disturbed the giant O-ring lately?
    If not, I personally would worry. Could be high, high pressure or even a crack. In my experience as a mechanic, I've found O-rings don't leak unless they've been taken apart and reused.
    But no matter what, you're gonna have to pull it apart to see, so I'd get a new O-ring standing by and some silicon lube for it, both available at the dreaded Pol Store. Long as it's apart, scrub the screens.
    I took it apart earlier in the season to clean the grids. Pressure is normal (<15psi). It was sealing tight for a few months but just started leaking.
