Thread: can you have algae with no CC and FC available?
    Oct 2007
    Central Texas
    104
    I have some green spots on the lights and drain covers which scrub off. Looks like algae but I have no CC. FC is available. Is it possible to have algae with no CC?
    FC 3.0
    CC 0.0
    pH 7.4
    TA 60
    CYA 30
    CH 960
    PH rise is a constant problem but I do have a large water feature that aerates.
    Light grey plaster, stone coping, 38K gallon Roman shaped pool with a shallow end beach, table and bar stools, deep end bench and waterfall (Intelliflo 4X160). Taylor K-2006, Pentair 320 chlorinator, Intelliflow VF, Quad DE 100. 4 ColorLogics, 3 skimmers, 14 wall returns, 13 floor returns, TurboTwister slide, autofill and miles of pvc.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: can you have algae with no CC and FC available?
    Yes. You should do an overnight chloine loss test (you have to turn off the liquidator to do this). If you lose more than 1ppm of FC overnight than you should shock.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Mar 2007
    San Rafael, CA USA
    12,082
    If there are areas of poor circulation then algae can form there, but the places you describe shouldn't have poor circulation -- especially not the drain cover assuming the drain is working (are you sure it's working?). There could have been some biofilms formed there at some point that take higher chlorine levels to get rid of so shocking and brushing are the right prescription at this point and then see if it comes back again after you get < 1 ppm FC overnight loss and let the FC drop back down to normal levels.
    You might also check behind the light in the light niche for algae and check under any removable ladders as well.
    Oct 2007
    Central Texas
    104
    I will definitely shock - I have only done it once and that was over a year ago. I have four lights and four drain covers so removing them all would be a chore.
