Thread: Stabilizer Question
    Evansville, IN
    65
    Stabilizer Question
    Can we swim after adding stabilizer to the pool? I added 4 LB yesterday and need to add 4 lb today.
    36X18 Inground Pool, SWG, Hayward Pump, Hayward gas heater, Undertrack Auto Cover, Interfab basketball system, TF-100 Test kit, Polaris 9300 Robot Cleaner, Pool Completed July 29 2010
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Stabilizer Question
    Yep.
    You're done SLAMing when:
    Evansville, IN
    65
    Thanks for quick reply. It is near 100 degrees (dewpoint 77) here in the Midwest and I'd like to jump in before I go to work.
    Butterfly's Avatar
    South Carolina
    10,045
    Enjoy!
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    As far as chlorine dosing you should assume that you reached the CYA target 24 hours after adding CYA (even though it may not show up on the test yet).
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
