Results 1 to 9 of 9
Thread: pool pillows
    Mar 2010
    Huntington, WV
    150
    pool pillows
    I just saw online and was wondering if anyone has used the pool pillows for closing down the pool? Are they good, worth the money?
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: pool pillows
    I used one last season and will likely use one again...my opinion is somewhat mixed...it helped keep the water and leaves etc out of the middle of the pool cover, hence keeping pressure of my walls when snow accumated, but there are many that get by without them. I would suggest using one in colder climates.
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Re: pool pillows
    Instead of the pillows --I use 3 truck inner tube tires in like a pyramid configuration tied together and then stick a 15" inner tube on top of that placed in the center of my pool and then tied off to my uprights. I installed a few D-ring tie downs to my uprights to hold this in place. When the water level is lowered below the skimmer--makes for almost a perfect "Teepee" type effect in the center and allows the rain to run off very easily. I don't get snow really here to worry about the weight on the cover--just excessive rain during the winter.
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    Western Pennsylvania
    151
    Re: pool pillows
    I use one, you really do need it if you are in a freezing climate.
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: pool pillows
    I don't use them for any of the above ground pools I close. Have yet to really see a benefit of them. They don't help with ice expansion (like a gizzmo in a skimmer) since they are on the surface of the water (unlike a gizzmo which is tethered to the skimmer). The only thing I think it does is push accumulated rain water to the edges of the pool which I guess some people could like? Although that's where I would put the pump to drain excess water off. Also making a tepee with with an airpillow and a tight cover voids the warranty of the cover.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Re: pool pillows
    For an above ground pool in a windy area when conditions are just "right" (or wrong depending on how you look at it) a pillow can help keep the wind from blowing all the water on the cover over to one side of the pool, which, in particularly extreme cases, can knock the pool wall over. Of course, you should never allow that much water to accumulate on the cover in the first place.
    Jun 2010
    Darlington, SC
    121
    Re: pool pillows
    Warranty on most of the above ground covers are a joke any how--they may give you one free year total replacement--but then it is based on the percentage per year of MSRP.. you can buy brand new ones from ebay for about 45 to 75 bucks depending on size and the weave.. This way I don't have to worry about the rain run off or the leaves next spring at opening. My way works for me and makes it simple to open and close the pool down. I will sacrifice the 15 to 20 bucks a winter to spare me the bleach lugging job of opening a swamp.
    Dolphin E10
    Jun 2010
    NE Ohio
    70
    Re: pool pillows
    I use one. It has an additional advantage of keeping the leaves and other debris closer to the edges which makes cleaning much easier.
    I also bought a small plastic battery powered sump pump that I use to drain water off the cover. I start the pump until it starts flowing and then shut it off...it just siphons the rest so you don't have to stand there watching it.
    Peter
    21' X 52" above ground
    1 HP Hayward Power Flow Matrix Pump
    Hayward EC40C DE Filter
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Re: pool pillows
    Quote Originally Posted by X-PertPool
    Bingo...
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
