Thread: Hayward Pure Swim SWG panel on the hot side.
    chris4150's Avatar
    Apr 2009
    Cypress, TX (suburb of Houston)
    180
    Hello all,
    Decided to switch over from ozone, nature 2, and inline chlorine feeder to a SWG. Texas heat was just too much on the CYA and FC and my set up could not keep above 2 ppm over a 2 day period. That being said, I had the SWG installed and Im in the process of getting everything up to speed when I noticed today that the control panel that is mounted on the side of my house (brick) is very hot to the touch in the area of the top right corner of the control panel box, almost to the point that you cant keep your fingers on this portion of the box (night time). Is this normal? Let me know what you think.
    chris
    13,500 gallon free form Pebble Tec pool- 2 skimmers
    Pentair Intelli-Flow filter pump, Pentair Intelli-Super Flo booster pump, waterfall pump, Del Ozone Eclipse 1 generator, Pentair Clean & Clear Plus Cartridge filtration, Nature 2 XG Clear Vision, In-line Chlorinator, Polaris 280, Raypack heater, and Color Logic LED lights.
    Proud user of BBB, pool school, pool calculator, TF-100, and the advice of the friendly people here!
    22,553
    Re: Hayward Pure Swim SWG panel on the hot side.
    Wherever the transformer is mounted is going to get pretty warm when the unit is generating. If you can keep your hand on it, it's less than 150ºF.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    chris4150's Avatar
    Apr 2009
    180
    Good deal. I just wanted to make sure that the heat being generated from the unit was normal. If not. I was going to call the installer back out.
    Jul 2007
    Brisbane, Australia
    874
    it's normal for transformers to heat up to 70 degrees C or even more if working at full output
