Thread: Pool Skimmer Draining
    Sep 2009
    Houston, TX
    117
    I'm having an odd issue. At least to me. The one pool skimmer is being drained by the pump (there's two skimmers). It's draining it all the way down to the point where it's just splashing in to an empty skimmer basket. No valves have been turned recently and the pool is very full. Any thoughts?
    15000 Gallons In ground, Ecobright pool finish, sand filter, Pentair intelliflo VS, SWG
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Pool Skimmer Draining
    is there a weir (ie skimmer door) stuck...either that or it sounds like a blockage
    Sep 2009
    Houston, TX
    117
    Actually I just went and messed with the weir and that seemed to do the trick. I pushed down the weir and it filled back up with water and stayed there. It really didn't seem stuck, more just not pressing down very far. I was messing with the weir the other day by pressing it down just to get some debris down in there. Wondering if this caused an issue.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Could be, also make sure your water level is at least 2/3 of the way up the skimmer opening
    Sep 2009
    Houston, TX
    117
    It couldn't get any higher. It's at the bottom of the drain built in to the pool. Is there any kind of adjustment on the weir doors that I could have affected by messing with it? Thanks Dman
