Thread: balancing water after conversion from baquacel to SWG
    Have just finished converting to chlorine and am trying to balance the water and start the SWG. My pool is a 28' diameter Dough Boy round AG with 1.5HP pump and sand filter. I have dumped in the salt and brushed it around but it is not yet all dissolved. Have also added CYA to raise level to 75ppm and am also waiting for it to dissolve (which apparently can take up to a week). My question is do I have to wait for everything to dissolve before I test for TA, CH, pH etc or can I go ahead and test and start the necessary corrections already. I went ahead and tested anyway just for the sake of it and pH was 7.0, TA was 110, CH was 250. Also, how soon can I let the kids start swimming?
    Steve Penney, 28' round Dough Boy AG pool, 18000 gallons, SWG, 1.5 HP pump, sand filter, converted from Baquacil August 2010.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: balancing water after conversion from baquacel to SWG
    Welcome to TFP...raise your PH to 7.2 using borax or aeration, other than that, make sure your CC's are 0.5 or less and you have passed the overnight FC loss test. Keep your FC at 5-8ppm and let the kids swim. You should be OK with 5ppm if you plan to use a swg, otherwise target 8ppm.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Salt and CYA do not interfere with the TA, CH, pH tests.
    Did you add the CYA in a sock? I have found that massaging the sock helps if dissolve faster. Even after it is visibly dissolved it can take a week to fully show up on the test. For the sake of chlorine dosing assume that you have already reached your target CYA level.
    Speaking of which, make sure you are keeping FC at recommended levels (8ppm) until the SWCG is up and running. A few days at 0 FC is enough to give algae a chance to get started.
    You will need to have muriatic acid on hand because with high TA and SWCG your pH will rise.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    When you converted, did you follow our recommendations, or did you use another method? Did you change your filter media?
    Ditto everything Sven said...
    Thanks for all the advice. Yes I used your method to convert and I did change the filter sand. Am planning on adding borax today and hopefully that will bring my pH up to a safe level.
