Thread: Patch Vs. Replaster
    May 2009
    West Texas
    20
    Patch Vs. Replaster
    Trying to decide whether or not to patch a hole in plaster in pool wall about 6' deep. Some people advise that patches don't last, will leak, and not match color of rest of pool. Of course, to completely replaster pool will cost about 15-16 times as much as the patch, but I would end up with a nice looking pool finish.
    The pool is about 25 years old, about 22,000 gal. in size.
    Any thoughts from some experienced pool repair folks?
    Jimwt
    Pool-21K IG Plaster, sand filter-98gpm, 1.5 HP pump @3450 rpm,
    Spa-600 IG Plaster, sand filter. 3/4 HP pump @ 3450 rpm
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Patch Vs. Replaster
    Pics?
    The pool is 25 years, is that the age of the surface or has it ever been replastered? If it hasn't been replastered, that's what I would recommend.
    May 2009
    West Texas
    20
    Thanks for your comment. I will probably opt for replastering. The plaster is 25 years old and somewhat stained. I tried asorbic acid treatment for stain last fall, but although it seemed to help somewhat, the stain is still present. Maybe I didn't use enough acid(2 lbs) and/or a bad sequesterant. Had planned to try again this fall, but replastering should solve that problem. I think an old heater that has been replaced put a lot of metal into the pool water so the staining problem shouldn't reoccur, hopefully.
    Any comments re/handling of a newly plastered pool?
    Jimwt
    Oct 2007
    Sydney Australia
    58
    Hi jimwt
    I'm convinced any hole can be successfully patched. If I had one hole to patch boy I'd be so happy. How big is the hole? If you can't match the patch could it be covered with a feature mosaic? You know like Marilyn Munro or a dolphin perhaps. What about another light for the pool?
    I suppose at 25 years you have to take a good look at the plaster. Any druminess? You can test by bouncing a golf ball around the empty shell. How thick is the plaster?
    I considered re-plaster but decided the existing plaster was still in good condition. My pool's plaster would be close to 40 years, it's still very sound. It averages 3/8 thick.
    Just some thoughts to consider.
    cheers
    Pools come 2nd to Sydney's golden beaches?
    21000g IG concrete pool (painted over marblesheen)
    1.5hp Waterco pump
    24"Waterco sand filter(artificial sand)
    SWCG
    Location Sydney Australia
    Aug 2009
    North Central Texas
    1,358
    A friend of mine had her 22 year old white plaster patched, some patches as big as 6". They are not really visible unless you are really looking for them. The patches are at least two years old and still holding on.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    May 2009
    West Texas
    20
    Thanks for the patch comments. I'm still considering the situation. If I drain the pool, I'll try the golf ball theory. I don't know the thickness of the plaster, but I'd guess it's about 1/4". Will check that further.
    Jimwt
