Results 1 to 15 of 15
Thread: SWG pros and cons for AGP
    I am going to buy a pools soon and cant decide to go with a SWG or not looking for some advice from people that have them or have had them.
    30' round AG pool 21,200 Gallons, 52" high, 1 1/2 HP Pump;
    25" 300lb. Cooper Ranger sand filter .
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: SWG pros and cons for AGP
    SWG. and I don't have one.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    SWG and I do have one
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    22,553
    SWG, and I knew a guy, that saw a guy, that had one once!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    SWG...have one, use one and love one
    Aug 2009
    North Central Texas
    1,358
    SWG and I don't have one either.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Guest
    Had three; never again I am obviously in the minority here though!
    Aug 2009
    SW Wisconsin
    518
    Have one, had one, will always have one.....wait is this advice on a SWG or an English lesson????
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Pros:
    1. Saves time and trouble.
    2. Not having to go get bleach.
    3. Not having to store bleach.
    4. Not having to handle bleach.
    5. Not running out of bleach.
    6. Salt makes the water feel better (of course, you can add salt anyway).
    Cons:
    1. Higher up front cost.
    2. Can cause pH to rise.
    In the long run, the cost will likely be about the same.
    18'x48" Intex metal frame pool, 1600 Intex sand filer/pump combo, Intex SWCG.
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by simicrintz
    When you have time can you elaborate?
    Thanks, gg=alice
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by rghilliard
    Pros:
    Cons:
    7. Not having to deal with recycling so many bottles.
    8. Not having to suffer the guilt of using so many containers even though you recycle. It takes energy to collect and transport the stuff and to repurpose it; although it does provide jobs for people.
    gg=alice
    Guest
    Quote Originally Posted by geekgranny
    Thanks, gg=alice
    Around here, we have high CH, and they "foul" often, which makes for a lot of work to clean. Additionally, the added run time to keep levels up during the season costs more for power.
    Honest answer is that if I had to pay for these units (which I don't; they give them to me) I would be unhappy with the down time. I hear a lot of "set it and forget it" stories on these, which is not true (in this area anyway). I also have the erosion issue on my flagstone, which I believe is accelerated from the SWCG. I would expect an easier, less maintenance product personally if I was paying for a unit. Heck, I don't even accept the maintenance work when I get them for free
    I'm looking for simpler, not more time cleaning a salt cell, higher energy bills and faster deterioration of my coping! In my area, I just don't think they are a viable solution. Your mileage may vary
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    <snip>Around here, we have high CH</snip>
    Bruce, I can think of a way to lower CH :P
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Guest
    Quote Originally Posted by svenpup
    You're learning
    Made me laugh; thank you!
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I just got done posting in another thread how my SWG has made me adore my pool again
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
