Results 1 to 10 of 10
Thread: Side Mount vs Top Mount Sand Filter....PROS, CONS?
    Jul 2010
    North Bergen, NJ
    172
    folks, In my quest for a 12,000 gal pool (14x28) I think the Hayward 24" Sand filter which handles 300lbs is the right match for the pool (if its not, please recommend another model) but I have a question about the differences in the top mount vs the side mount....and also, I am a bit confused about the valve. Do I need to purchase a seperate valve?...there is a slide valve and a variable valve?....and then 1 1/2" vs 2"
    Im a little confused again as to what I need to match everything with the rest of my pool purchase.
    Im getting a Tri Star 2 speed 1hp pump (and plan on running it most of the time at 1/2hp on my 12,000 gal pool) I asked the builder to use 2" plumbing all around and Im not even sure if I will gain any benefit from this. So can you recommend what I should match with the above?
    Thanks, and mods, I apologize in advance if this should have went somewhere else but I figured it warranted a seperate topic because perhaps others would like to know the pros and cons of a top vs side mount sand filter
    thanks,
    Lori
    Design 14x26 (10,000 gal) in ground vinyl pool, 2 Wide Mouth Skimmers, 3 Returns
    Equip 3.0 HP Pentair VS pump motor, 48 FNS Plus DE filter, IC20 SWCG, 400Btu NG Heater
    Extras Easy Touch Automation, Pentair LED Lite, Kreepy Krawl Racer pressure cleaner
    Water pH 7.5, Total Alk 90, Free Cl 4.5, Combine Cl 0.25, CYA 65, CH 275, Salt 4100ppm, Borates (Boric Acid) 50ppm
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Side Mount vs Top Mount Sand Filter....PROS, CONS?
    Search is your friend!
    top-mount-vs-side-mount-multiport-t19426.html
    The multiport valve is usually included in the filter price
    Side mount is slightly easier to use in the long run and usually a little more expensive. Rotary multi-port valves are better, and again usually a little more expensive.
    Some filters come with the valve, some don't. Top mounts come with the valve, and some side mounts also include the valve.
    2" ports are better, but it doesn't make much difference.
    Low speed on a 1 HP pump isn't 1/2 HP, it is 1/8 HP.
    Jul 2010
    North Bergen, NJ
    172
    thanks...the link you gave was very helpful, in regards to the correct size filter and getting 2" plumbing all around, can you provide some feeback...thanks again
    Lori
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    2" plumbing will provide better flow rate and a 300lb sand filter is more than sufficient.
    2" is better, but it is typically only a small difference. Normally the price is only the slightest bit more, so larger plumbing is typically well worth the tiny additional cost.
    Jul 2010
    North Bergen, NJ
    172
    my only confusion with the 2" plumbing is when I ask the pb to put in 2" plumbing all around, he said ,you dont need it all around , he would plumb it 2" in certain areas and then fit it down to 1 1/2" . However I dont remember where he said he would/recommended to do this.... Any idea what he is referring to? and should I ask for 2" all throughout?
    thanks
    South Central NJ
    3,192
    Please note that a 300 pound sand filter's internal stand pipe is 1.5" and putting a 2" multiport , at least with a Hayward S244 or Pentair Sand Dollar, does nothing to improve the flow through it. It's less costly to simply use a male adapter with 1.5" male threads and 2" socket connections.
    The biggest reason to use a side mount filter is vertical space available unless the tank is a 36" diameter at which point the side mount becomes easier to use due to reach.
    Scott
    Owner of - PoolGuyNJ LLC
    Jul 2010
    North Bergen, NJ
    172
    do both side mount and top mount hayward sand filters offer the ability to view the backwashing? Sorry if thats a stupid question
    South Central NJ
    3,192
    Yes, both use the same sight glass.
    Scott
