Thread: Algae in a clear pool
    I am having a problem with a green algae ring around the outer edge of the pool . It seems to have started after changing the pump ( down graded from 1.5 h.p. to 1 h.p. ) choline level and p.h are in range and pool water is crystal clear . . The pool is a 15000 gal., above ground pool and I am running with a d.e. filter . Also I have changed the D.E. atleast 3 time this summer . I also have discovered a couple of leaks in the liner which I have repaired . The liner is 12 years old . This green stain comes off with a little elbow grease, but comes right back. Any help would be great.
    35,000 gallon 800 Sq. foot gunite, 50 x 22 freeform. 2 sheer Descent waterfalls from 2 foot raised beam wall, Jandy heater, Polaris 280, 2 H.P. pump, DE 60 filter, Nature2, 2 Jandy color lights, 1000 Sq foot of Stamped concrete.
    Master Spa LS850
    That sounds like what happens when you have algae in a pool with low phosphates. In any case you need to shock the pool in order to kill the algae.
