Thread: Styrofoam base for pool.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Hello everyone,
    I know this has probably been asked before but I can't seem to find a definite answer. I'm going to redo the base for my 16' x 48" round Intex Ultra frame pool. I will be using styrofoam and sand as the base.
    Questions:
    1. Can the styrofoam be subjected to the weather?
    2. Does it need to be covered?
    3. Is the below order OK?
    Pool Base setup:
    1. Tamped level ground.
    2. Thin layer of sand for final leveling
    3. 1.5" or 2" styrofoam
    4. Ground cloth if needed.
    5. Pool
    Thanks, Mark
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Re: Styrofoam base for pool.
    Mark,
    The styrofoam will weather/oxidize. the pink stuff gets lighter pink and pills up when you touch it.
    A good quality tarp covering the foam is the way to go. I used the HD silver one, on my 3rd year w/o a prob. but might need to replace it next year.
    Also, I see that you are looking to upgrade to the 20' any reason you are not going to the 24' ?
    Mike
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    crookm11's Avatar
    Jun 2010
    422
    Quote Originally Posted by mcoonan
    Mark,
    Mike
    mcoonan,
    Thanks for the reply. I kinda figured the styrofoam would weather if not covered. I decided to go with the 20' instead of the 24' because I can't seem to find either one for sale anywhere so I have to peice the pool together from the Intex store. The part numbers for the 20' match the part numbers for the 16' so I can use my current legs and "T" brackets and just have to order a few instead of all the parts for the 24'. I would love to have the 24'.
    Thanks again, Mark
    Mark Crook
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Mark,
    If you know anybody in or around Louisville, KY here is a 24' for cheap:
    http://louisville.craigslist.org/for/1864859469.html
    Or Maine:
    http://maine.craigslist.org/for/1822616635.html
    Mike
    Aquabot Pool Rover
