Thread: newbie Pump questions
    Hello,
    I have a DE filter, has a shutoff before the pump, and eyeball replacement to shut off back flow from the return, an air relief valve, and a drain. That is all of the option I have. My question is this--how the heck do I clean the pump strainer without water coming out everywhere? Also--it is a two speed pump. On high the pressure reads anout 10, and on low it reads about 1 or 2. Is such low pressure normal?
    Thank you !
    24' AG Doughboy w/ 5'8 dish bottom, CWII DE Filter, 1.5 hayward 2 speed pump, Aquatrol SWG.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: newbie Pump questions
    That pressure sounds normal for a 2 speed. Its pretty difficult to stop all flow of water to clean out the pump basket. closing your valves and plugging holes is pretty much all you can do but you still have a lot of water in the lines and the filter itself. Clean it quick... LOL
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Assuming you are talking about an AG pool, low pressure is normal.
    Do you still get water if you shut the valve off and plug the return?
    Thanks all--it is an abg--and yes, with both plugged water comes out--as I would assume it would, as it the lowest point. Just checking to make sure it was normal. Thanks!
