Thread: Is there a diffrence between TA and alkalinity?
    Jul 2010
    Fredericksburg, VA
    24
    I just had Pebble tec installed, and the instructions are to keep alkalinity bellow 70 during the first 72 hours. I used 2 gal of muriatic acid to bring TA to 120 and PH 7.2.
    The instructions say " lower the alkalinity..." not "lower TA..." 27K gal pool.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Is there a diffrence between TA and alkalinity?
    TA=Total alkalinity
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Jul 2010
    Fredericksburg, VA
    24
    I still do not know if both terms are the same.
    Dec 2009
    2,690
    Yes, TA stands for alkalinity, they are the same. People use the terms total alkalinity and alkalinity interchangeably. TA= alkalinity for the purposes here, yes, it's the same thing.
    (yes, I know the nuances, but for the purpose here, they can be used as the same thing)
    What bk406 said. In this context, yes they are the same.
