Results 1 to 8 of 8
Thread: Frustating Green Pool
    St. Louis, Mo.
    16
    My pool is has been green for a week now coming back from vacation. I've adjusted the chemicals, but the pool is still green. My readings from 10 minutes ago is. Should I add more bleach?
    CC- 5
    FC- 5
    PH- 7.8
    TA- 120
    CH- 160
    CYA- 50
    Grecian/W a Step style,14ft by 30ft
    14,000 gallon,Fiberglass,
    Sand Filter
    Deepend 5ft
    Method(BBB)
    Nov 2009
    Indialantic, FL
    323
    Re: Frustating Green Pool
    based on the CYA/chlorine chart - pool-school/chlorine_cya_chart_shock
    I would say yes. Time for a stroll through the pool school.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Mar 2010
    Spring, TX
    1,082
    Should that CC be FC and the FC be TC? That CC is way to high.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    St. Louis, Mo.
    16
    The cc should be the first reading of chlorine and the FC was the second reading. I hope that isn't to confusing.
    Sand Filter
    Deepend 5ft
    Method(BBB)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    FC + CC = TC so if your CC is indeed 5 then you have a problem.
    Looks like you may be testing with a DPD test - you need an FAS-DPD test - which is easier to determine CC counts and also can test FC up to 50ppm - and since your shock level is 20, your test won't go that high....
    You need to shock the pool, and purchase an FAS-DPD test.
    Shock until the FC holds overnight
    the CC is .5 or less
    the water is crystal.
    JoeH20's Avatar
    North Texas
    15
    1. Go to http://www.poolcalculator.com and plug in your existing values in the "now" column;
    2. In the last row "Suggested Goal Levels" select "TroubleFreePool.com" in "Use suggested goal levels from:"
    3. Select "Bleach" for "Primary source of chlorine"
    4. Select "Fiberglass" for pool surface
    5. In "Target" column for FC select 16 (this is the recommended value for Shocking based on your CYA levels - see recommended FC levels in second to last row)
    6. In the third column in the "FC" row set to your bleach %/jug size. In my case I get big ultra bleach jugs from Sams so it's 6% bleach/182 oz. Yours might be different. Float your mouse over the "Add 319 oz" and it will show you how many gallons (or jugs) to add in the white field. For you it's 2 gallons 2 quarts or 1.8 (182 oz) jugs."
    7. Add this amount to your pool at night with the filter running (run 24/7 until process is done). Next morning retest (using a Fas DPD kit - see this link: http://www.troublefreepool.com/pool-...kit_comparison. The Fas DPD measure is the only way to test chlorine higher than 4 or so. If you don't have it it's almost a waste of time to shock although you could try if you don't have it and just shock until clear).
    8. Go back to http://www.poolcalculator.com. Repeat above steps, adjusting the "Now" column to reflect the morning's pool read. Add the amount of chlorine to get it back to 16.
    9. Repeat the prior step at night. Repeat this procedure morning and night until the pool is clear. When it is clear, at night test again an hour after you put in whatever chlorine you need to get it back to the shock level. Next morning test again - if the difference between the morning's test and the previous night's test is 1 ppm or less you are done. Otherwise keep shocking morning and night until your difference is 1 ppm or less.
    10. Read these for background and reference:
    http://www.troublefreepool.com/pool-...efeating_algae
    http://www.troublefreepool.com/pool-...king_your_pool
    and generally: http://www.troublefreepool.com/pool-school/
    11. My experience has been that the key is shocking to the shock level recommended by the pool calculator based on the CYA. If you don't have the CYA plugged in right or don't consistently shock to the level recommended based on the CYA (in this case 16) even if it seems high, you will spend endless days and $$ and chlorine trying to get the pool clear. Bite the bullet and put in the high levels of chlorine up front, keep it to that level until done, and you will get a clear pool.
    12. I would recommend getting the PH down to 7.2 also before shocking as low ph helps to make the chlorine more effective.
    13. When done, keep the chlorine at the regular non-shock level recommended by the poolcalculator.
    20k, Plaster IG, Tagelus Fiberglass Sand Filter TA-100D Flow Rate 100, Pentair 2HP Pump, Polaris 280 Pool Cleaner, Taylor K-2005 Test Kit
    St. Louis, Mo.
    16
    I will do all this and thank you for your help. It never has gotten this bad before. The test kit I have is a Taylor. I wonder if the hot weather in the 100's mix with 15minute down pours of rain every other day has something to do with it?
    Sand Filter
    Deepend 5ft
    Method(BBB)
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by brettman40
