Thread: hayward 400 heat exchanger leak
    I have a 4 year old H 400 with a leaking heat exchanger. I am a plumbing contractor, not a pool contractor. Anyone have any luck soldering the leak?
    Figure 8 20'-6" X 35' Inground Pool - Shallow End 3'-6", Deep End 8" - 23,000 gallon pool - Hayward DE 7220 Vertical Grid DE filter - Hayward Mineral Sanitizing System - Hayward
    my-pool-t62997.html
    South Central NJ
    3,192
    Re: hayward 400 heat exchanger leak
    Can be done if it's a copper HE and if it's a tube. If it's leaking at the face where it meets the manifold, time for a new HE.
    Lesson learned: No tabs in the skimmer and keep the pH close to 7.5 so it doesn't get eaten.
    Additional Note: If you have a 2HP or bigger pump, a bypass should be plumbed to avoid pushing too much water through the heater, volume wise. A low head system with a big pump can push more than the heater should be asked to accomodate.
    Scott
    Owner of - PoolGuyNJ LLC
