Results 1 to 9 of 9
Thread: Rainwater and hardness
    solarboy's Avatar
    Aug 2010
    Europe
    337
    I'm going to be draining my pool this winter to tile it. I was thinking of refilling with rainwater but I would have a problem with lack of hardness causing corrosion, especially as it is a concrete pool.
    My well doesn't produce enough to fill my pool nicely, it takes 3 weeks and drags lots of sediment that have to be removed, but other than that it is nice water and easily balances. The well water is used by the house and takes ages to clear up after.
    I looked at the price of hardness increaser from my pool supplier. I get this at trade price but even so it was so much money as I need around 15-20 kilos (33-44 lbs).
    Is there a cheaper way of raising CH? I have access to things like slaked lime, calcium hydroxide etc
    Thanks in advance
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Guest
    Re: Rainwater and hardness
    Why wouldn't you just buy a 50lb bag of calcium chloride???
    http://www.acehardwareoutlet.com/produc ... KU=7208895
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Where I am in Portugal we don't get snow, hence no Calcium Chloride in that form, in fact I am Googling "Clorito de Calcio" and I've not found anything yet.
    Calcium chloride is also sold in the concrete industry, where it is used to accelerate curing. Neither of the two most common uses (deicing & concrete accelerant) are common in warm/tropical areas, where it can be rather difficult to find calcium chloride.
    Guest
    Calcium chloride is also sold for the concrete industry where it is used to accelerate curing. Neither of those uses are common in warm/tropical areas, where it can be rather difficult to find.
    Huh???
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Yep, I've poured a lot of concrete and not ever needed an accelerator. I did find some vague agricultural links but nothing useful yet.
    Guest
    Do you have any chemical distributors in Portugal?? Like here http://www.galladechem.com
    Quote Originally Posted by salp
    Huh???
    Try my improved wording, above.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    OK, sorry to bump this but I didn't get resolution last time and I have since found out that I can use Calcium Hydroxide, of which I have plenty but it will impact pH. I also haven't a clue on the dosing. Can anyone help with this?
