Results 1 to 10 of 10
Thread: Aqua Rite keeps blowing fuses
    Please only ask any given question in one place. Topics merged. JasonLion
    I have owned an Aqua Rite system for about 5 years. Last year I replaced the generator for the first time. Ever since I have been blowing fuses quite frequently. Any ideas as to why this is happening and what can be done to correct.
    Blowing Fuses
    South Central NJ
    3,192
    Re: Blowing Fuses
    Possibilities:
    High salt will increase the water's conductivity, allowing too much current. It usually senses this but stuff happens.
    Larger cell and the controller doesn't know it.
    Dirty power source.
    Bridge rectifier failing.
    Poor ventilation.
    Bent pins on the connector.
    That's about all I can think of without seeing it.
    Scott
    Owner of - PoolGuyNJ LLC
    South Central NJ
    3,192
    Re: Aqua Rite keeps blowing fuses
    I answered this when you asked int the SWG topic area.
    blowing-fuses-t25922.html
    Lets keep it there. This topic area here is meant for people new to pools and BBB.
    Scott
    Jul 2007
    Brisbane, Australia
    874
    Re: Blowing Fuses
    another thing could be - metal debris inside the cell shorting out plates
    Normally it means you have a short. Check your wires and make sure they are tight and not touching anything else. Turn off your power at the breaker box first
    JoshU's Avatar
    New Orleans, LA
    542
    See any damage to the board? Check for burn marks on the front and back of the board.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Jun 2013
    Bel Air Maryland
    21
    where is the bridge retifier
    30,000 gals./ In ground/Vinyl liner/Cartridge filter/A.O Smith 1 1/2 HP Pump/Pool Installed in 2008/Tf-100 test kit just ordered/Aqua-Rite SWG/well water
    Jun 2013
    Bel Air Maryland
    21
    I cannot seem to get any help from my pool place regerding my aqua rite.I took the board off and there are no burn marks,replaced fuse holder,tried new fuses and same as usual when installed it blew instantly.I have a 40,000 gal inground with vinyl liner.Can this be the same problem that i see on other post the little black thing the size of a quarter?What else can i try.I am very handy but do not know what to do next.Please help
    Quote Originally Posted by larbec
    This is a good point. Check your polarity as too it can make all the difference.
    24' round AG 15K gals. DIY solar heater. SolarChlor Max producing free chlorine!!. Pool is crystal clear!! Doing my best to use natural products or processes.
