Thread: Installing anchors for winter cover ?
    NJ
    291
    I just ordered a winter cover that has brass anchors that get installed into the concrete decking around the pool. Can anyone who has done this give me some advice on how it should be done, what problems I might run into and any other tips or tricks before I start.
    Thanks
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    Haven't done it myself, but you might want to check out this website for step-by-step instructions:
    http://www.poolcenter.com/loopinst.htm
    inground gunite, 18x38 freeform, 3'-9' w/ diving; 3M caymen green/blue blend; Pentair 2HP whisperflo; + aux pump for water feature; SWG; Rheem heat pump; Polaris 380; Pentair TR 100 sand filter; silverlake flagstone coping/broom finish concrete deck; NPTG Aztec cobalt tile; 18" bond beam wall with water feature
    When you drill into the concrete for the anchors make sure you are using a brand new drill bit. If you can find one a coring type bit will cut a nicer hole without the possibilty of chipping near the edge of the hole. If you do chip the edge you can buy inserts that have a small flange on them that will cover the damaged area.
    As for getting the cover on and the anchors in the correct position. Unfold the cover over the pool, if yoy have a solar cover use this underneath as it prevents the cover from sinking too much. Make sure that the amount of the cover that overlaps the edge of the pool is even around the pool. starting from the middle of the cover at the ends of the pool mark and drill for the anchors at both ends of the pool. You can then finish drilling the rest of the holes working away from the ones you have already done.
    ~Megan
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I used a 3/4" standard masonry bit in a hammer drill. It's still a bunch of work, but saves you a bunch of money over paying for the install. Don't go cheap with the bit.
    A coring drill would probably give beautiful holes, but the ones I've seen are very, very slow compared to standard bits, and they require cooling water.
    Jul 2007
    Suwanee, GA
    528
    As suggested, use a good quality new bit and a hammer drill. The hammer drill is tough on the hands, but will make quick work of it, especially if drilling into old concrete.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
