Thread: How to measure salt
    How to measure salt
    Now that I've conquered the BBB method, after reading a lot of other great info on this forum I'm now contemplating adding salt to my pool for the apparent silky feel it and shimmering look it provides. I don't have a SWG, but I understand you can still add salt to your pool for these other benefits.
    So my question is what is the best way to measure salt? The only thing I'm seeing out there are test strips. Is that the recommended method used for this testing?
    WalMart sells a combination kit of salt test strips plus another vial or 6-way test strips, but it's $16.99 and a waste of at least half of the supplies as I no longer use 6-way test strips (I've seen the TF100 light!!). I checked online and Leslie's apparently sells a salt test strip kit for $12.99.
    I just wasn't sure if there was a drop test or something else available and thought I'd check with my expert TFP friends first!
    20'6" X 38'6" (609 sqft)
    22,500 gal gunite/plaster IGP
    DE filter, Jandy 2HP pump, Nature2 Sanitizer (removed cartridge!)
    Raypak 39.9K BTU gas heater
    2 ColorLogic lights, Maytronics Dolphin pool cleaner
    South Central NJ
    3,192
    Re: How to measure salt
    Strips will be you most economical. Aquacheck makes them and tftestkits.net sells them.
    Scott
    Owner of - PoolGuyNJ LLC
