Thread: White specks on bottom of pool
    Jul 2010
    northern California
    235
    I have a pebbletec pool. I am in the middle of shocking for mustard algae. This is the 5th night that I am trying to keep FC at 24. I notice tonight that there are a lot of white specks at the bottom of the pool. I cannot tell if some of the pebbles came loose or got bleached out because I had put so much chlorine in the pool since Monday night. All I know is that there are a lot of white specks on the bottom of the pool that I have neve seen before. Had this happen to anyone else?
    IG pebbletec pool: size of pool: 27,000 gal; filter: cartridge - Hayward Superstar Clear; pump size: 1.5 HP; TF 100 Test kit - got it on 7-29-10; The Pool Cleaner-4-wheel suction model; Pool calculator: http://www.poolcalculator.com/; bleach calc: http://troublefreepool.com/files/BleachCalc262.exe
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: White specks on bottom of pool
    Not to me, but I can assure you that you didn't bleach the pebbles.
    Jul 2010
    northern California
    235
    Oh no, then the pebbles must have gotten lose and got vacuumed by the pool vac. The pool is about 15 years old.
