Thread: Finally up and running!
    We finally have our pool up an running. I will spare everyone the gory details, but here is a summary, looooong ground prep, walls up, connectors plates on wrong, wall off, wind, pool together, thunderstorms with high winds, wall collapsed, wall back up, liner in, water guy (who also installs pools) had us trying to stretch liner too much, liner rips, new liner, more water and now we are swimming. I hope this pool lasts a long time, cause I don't think I ever want to do this again! Anyway, here is a pic of the finished product.[attachment=0:lc1x1qbx]DSC01305 (Small).JPG[/attachment:lc1x1qbx]
    Here are my test results
    FC 3
    CC 0
    ph 7.3
    T/A 140
    CH 110
    CYA 20
    Started with just bleach and CYA. Water looks pretty good, maybe could be a bit clearer. Any suggestions? Pool sees full sun pretty much all day, water temp is about 86 degrees.
    Also getting a lot of very tiny bubbles through the return. Do I need to bleed air from somewhere? If so, how? Thanks!
    24 ft, 52" Patriot Vista AGP, steel wall, dished bottom, 14,300 gallons
    Hayward 1 hp pump, S180T sand filter, 2 - 2 X 20 solar heating panels, solar cover and reel, 8 gal Liquidator, TF100 test kit
    Jan 2010
    Randleman,NC
    620
    Re: Finally up and running!
    Nice looking pool..I decided to replace my liner myself..I want do that nomore.lol..Enjoy!!!
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    You might want to bump up your CYA a bit to 30 or 40. At 20 ppm you will burn off your chlorine faster than desired. You could also bump the FC up 1 or 2 ppm. When you say it "could be a bit clearer" what does it look like exactly? The TA seems high, but am not sure if it is any factor.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Thanks for the reply Carlos. I will grab a little more CYA and bump it up to 30-40.. The water seems pretty clear, but I would not say it "sparkles ". Maybe I am just being too picky?
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    no. not being too picky. Once you have the sparkly water you will ALWAYS want to have sparkly water.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
