Results 1 to 16 of 16
Thread: Goldline Aqualogic PS-4
    Hello...
    Keep getting a message on display...CHECK SYSTEM LOW VOLTS.
    Cert. dealer here yesterday....T-15 cell works good....
    Circuit board....transformer output readings good
    Solar system no issues
    HELP! BAFFLED! NO ANSWERS! HELP!
    South Central NJ
    3,192
    Re: Goldline Aqualogic PS-4
    Could be:
    High Salt
    Failing bridge rectifier
    Corrosion on the connections
    Failing transformer leg
    Scott
    Owner of - PoolGuyNJ LLC
    Salts are are 3000 ppm
    Appreciate the response.
    Wish there were more like you in Las Vegas...refering to your quote under your sig....
    Here in Las Vegas it still is like the wild wild west.....
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,053
    Welcome to TFP
    I feel your pain You need to move to Florida
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Thanks all for comments....
    NOW....
    What do I do first?
    Main board replacement
    or
    Replace T-15 cell
    Either way I know $$$$$$$$$ are involved.....
    I am just a disabled vet but feedback is appreciated.
    To many cowboys in Vegas ...rob you blind and smile as they do it!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Find someone who knows how to use a digital voltmeter and then call Goldline's support #. They'll make you wait ~ 30 min on hold but then will walk you through what to test to find out which part is bad. Short of being able to do that, I'd start with the rectifiers
    Luv& Luk
    -Ted
    Pumps are running....
    Now no reading for salt at all....
    If pumps are running, everything working except no salt numbers...suspect the t-15 cell did die.
    Feedback please.
    Thanks for the patience all.
    maybe just shut ever thing down..hook a hose up to fire hydrant and just enjoy that..............
    mas985's Avatar
    Pleasanton, CA
    11,737
    First, make sure the cell is clean.
    Then go to the diagnostic menu and click to the first entry. It should read the volts and amps of the cell. Report back.
    If the cell were failing, current should drop but not voltage. Too much salt would tend to drop the voltage some but current will rise and then you should get a high salt warning and not a low voltage warning.
    The PS-4 is notorious for failing in the power supply circuit, specifically a solder joint on the board which burns out. This can be diagnosed/fixed with this proceedure.
    Mark
    Reporting back...
    Cell is 100 per cent clean!
    When to Diagnostic Menu....Readings were all ZERO except air temp 85 degrees....
    Standing by....
    mas985's Avatar
    Pleasanton, CA
    11,737
    Did you press the "+" button while reading the voltage/amps to start the cycle over? Try that first. If it is still 0 readings then it sounds like a board failure which is explained in the link I posted above. Look at the proceedure and see if you are comfortable taking care of this yourself and make sure you turn off all the breakers to the panel before proceeding.
    Mark
    I want to THANK EVERYONE FOR THE ASSISTANCE...
    BOTTOM LINE.....
    Will skip all my medications for a month to save up for a new motherboard. Did all the tests as recommended and looks like a board failure.
    I surely will tip my hat off to each and one everyone on this board.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Did you check to see if it is the solder joint? You may be able to fix the board instead of replacing it.
    Mark
    Did the fix as recommended...NO GO! New board will come with 1 year warranty.
    Looks like I've run into the same problem, no voltage, no amps, and only a TCell temperature reading. What would be causing the motherboards to be going bad? My system is only 3 years old.
    -Terry
    22,544
    A lot of things can cuase the boards to fail. Bad design or manufacture is the case with the solder joints. Power surges are a major culprit in most electronic part failures. Even if you don't know there was a surge or spike it takes a toll on the components.
