Results 1 to 13 of 13
Thread: Newbie help with numbers
    Aug 2007
    West Texas
    56
    I am so glad I found this site. We are new pool owners and need some help. We have recently had a lot of rain and have had issues with mustard algae. The algae is gone, for now. We have an inground, plaster, approx. 23,000 gallon pool with a spill over spa. I just received my FAS-DPD kit today and these are my numbers:
    PH 7.4
    TA 80
    CH 425
    FC 0.5
    CC 1
    CYA 55
    We are in the desert southwest with a lot of sun and hard water. I have been using what came with the pool for chemicals, but prefer to use the BBB method.
    Thank you all in advance for any help. I sure can use it.
    Vonda
    23k gallon, IG, plaster with spillover spa, Hayward pump and filter
    Welcome to TFP!
    With CC of 1 you should shock the pool. With a CYA of 55 that means bringing FC up to 17 and holding it there by retesting and adding more chlorine to bring it back up to 17 reguarly until your CC reading is zero. Once you have gotten rid of the CC, you should maintain FC so it never goes below 4, aim a little higher to give youself some margin.
    Other than that your numbers are looking fairly good.
    gonefishin's Avatar
    Joliet, Il.
    413
    Hi Vonda...welcome to the site.
    You've got some elevated CC levels so you'll want to shock your pool (Check this post for newbie info on shocking). It can be difficult to maintain chlorine levels during periods of heavy rains. During these times (of heavy rains) I can't think of any reason not to add additional chlorine ahead of the rain, instead of taking a chance that it runs down to zero. But we'll see what the more experienced have to say about this??? I would think you'll want to start shocking as soon as possible to ensure the algae doesn't have a chance to come back.
    good luck!
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    Arizona
    924
    Hi and welcome! I have a friend named Vonda.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Vonda, and welcome to TFP! You're gonna like it here
    Joyce
    You're done SLAMing when:
    Aug 2007
    West Texas
    56
    Thank you all for the warm welcome and advice. I added one bag of shock and 4 gallons of bleach last night (I hope it's ok to mix them). I ran the pump through the night and today my readings are:
    FC - 13.5
    CC - 0
    PH - 7.6
    I'm not sure how much more shock to add. Right now all I have are the bags from the pool store. Should I test the other numbers as well?
    Thank you again,
    Vonda
    Buggs - ask your friend why her parents named her Vonda?
    30,415
    Numbers look like you probably don't have to shock again. How does your water look?
    If your water is clear, and you've already tested for 0 CC's, the best thing to do next is Test your FC tonight after the Sun is off the pool and then test again tomorrow morning. If you lose 1ppm or less FC overnight, you're all set. If you drop more than that, you need to shock again.
    Congratulations! The primary goal was to get CC down to zero, which you have done. At this point you can let the FC drift down and only add more chlorine to keep it above 4.
    My Pool Calculator, see the link in my signature, is a handy way to figure out how much chlorine to add to reach a target FC level.
    If you want to be really through you can measure the FC level this evening after sunset and then test it again tomorrow as early in the morning as possible and see if you are losing any FC overnight. I doubt there will be any loss, but if there is you should bring it back up to shock level and hold it there until there isn't any chlorine loss overnight.
    Arizona
    924
    I'd back away from using the pool store shock - your CYA is already pretty high. Save it for later, if your CYA gets low.
    I'll ask her about her name. I take it there is a special meaning to the name? I know my friends mother is from England, so I just figured it must have been a common name there or a family name.
    Buggs
    Aug 2007
    West Texas
    56
    Thank you all again. My water looks crystal blue. I will check everything in the morning. I have ordered the Lamotte Borate test strips and plan on completely changing over to the BBB.
    Vonda
    Buggs - I was named after Miss America 1965 - Vonda Kay VanDyke. She was crowned September 13, 1964. She is originally from Michigan and was Miss Arizona. I was born in October of 1964 and my maiden last name was quite similar, so my dad thought they would be great names.
    Aug 2007
    West Texas
    56
    After a night of numerous teenage girls in the pool and a late night downpour, here are my numbers:
    FC - 10.5
    CC - 0
    OH - 7.4
    CH - 425
    TA - 90
    CYA - 70
    I don't know why the CYA went up. I tested twice to be sure. What do I do now?
    Vonda
    You are fine. Just keep FC at 5 or higher, test reguarly to see if the PH drifts, and enjoy the pool!
    Aug 2007
    West Texas
    56
    Thank you all so much.
    Vonda
