Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Pump Motor Replacement Q's
    I have a Hayward Super Pump witha 1.5hp motor. At the start of the season, the pool guy told us the motor was on it's way out, but would last the season. Last night, the pump kicked on but sounded louder than usual. After a couple of minutes it started smoking, popped the breaker and shut down. I've got a replacement motor coming, but I've never pulled the pump apart before, what kind of job am I looking at? Does the motor just slide out of the pump, or does the whole pump need to be disassembled? The motor is due in on Weds, and I go away on vacation Sat AM, so I'm going to be short on time...
    Re: Pump Motor Replacement Q's
    If it arrives at 5:00 pm, you should be done by 5:30 or 6:00 pm. It's that simple. You may want to go to the Hayward website and download the manual for your pump, it should have an exploded view you can look at and get familiar with it before the motor arrives.
    Good luck
    22,545
    You'll have to remove the pump from the volute, then the 4 bolts that hold the motor onto it then unscrew the impeller then remove the motor. Did you buy a seal while you were at it?
    No, what seal do I need? Is it a common pool supply store part, or something I need to mail order?
    22,545
    It's the shaft seal. It's a good idea to replace it anytime you break the pump and motor apart. The local pool store should stock them.
    Mar 2009
    Huntsville, AL
    156
    The following are links to a two-part Youtube video for replacing the shaft seal in a Super Pump (I think there are only four more bolts to remove to change the motor).
    http://www.youtube.com/profile?user=...27/e1RWd6lae9Q
    http://www.youtube.com/profile?user=...26/WT6FaK3MX4o
    Hope that helps.
    Gordon
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    I've got a post or 2 here on replacing motors and seal assemblies on Super Pumps (the seal assembly is SP 1600 Z 2) search for "seal assembly" and "waste" as the author.
    If you still need help, ask - I could do this blindfolded
    Luv& Luk
    -Ted
    I got the pump in yesterday, and I picked up the seal today. It's a PSR seal, by Alladin, part number PS201. Does that sound correct? The person behind the counter didn't seem sure...
    South Central NJ
    3,192
    That's the seal.
    Tools needed:
    1/4" Nut Driver, Needle Nosed Pliers, 9/16" And 1/2" Sockets with a Ratchet with Extensions Slightly longer than the motor (Makes life easier!), Volt Meter, Flat Head Screwdriver (#2) 7/16" Open End Wrench
    1) Shut off power
    2) Remove cap from the back of the motor using the nut driver. If the bolts snap, so what.
    3) Disconnect the wires
    4) Disassemble the power conduit and pull the wires through the connection on the motor. Remove the elbow from the motor after. Don't forget the bond wire.
    5) Remove the clamp holding the capacitor and move the capacitor so you can see the shaft behind the spring loaded centrifugal switch.
    6) Remove the four 9/16" bolts holding the seal plate (motor is still attached to it) to the pump body. Slide it back.
    7) Remove the Volute to expose the impeller.
    8) Insert the 7/16" wrench into the shaft behind the spring loaded centrifugal switch. Spin the impeller until the wrench slides onto the shaft. This will act a a wedge to hold the shaft. Unthread the impeller off the shaft.
    9) Remove the four 1/2" bolts holding the motor to the seal plate.
    10) Remove the seal set from the seal plate and impeller
    If the impeller appears worn, replace it.
    Use even pressure when pressing the seal for the the seal plate into position. I usually use a deep socket turned backwards.
    Check the volute gasket too.
    Reassemble in reverse order with the new motor. The Volute and seal plate are labeled Top for orientation purposes. Do over tighter the 9/16" bolts. The nuts are only pressed into the pump body. If they let go, there are replacements available but they are not normally stocked by most pool stores and it may take some time to get.
    Before wiring it back up, Use a volt meter to verify if the pump is 120VAC or 240VAC. The wiring diagram is on the motor.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2007
    4,160
    (PSST, Scott - all the bolts are 9/16 - But I won't tell anyone :P )
    Luv& Luk
    -Ted
    South Central NJ
    3,192
    I hate it when I brain fault.
    Scott
    Thanks for all the help guys! I installed the impeller and housing on the new motor last night and it's all set for the install into the pump tonight. My only question is on the wiring...does it matter whether the hot or neutral goes on either the L1 or L2 connector?
    Quote Originally Posted by ted13b
    Yes, and there should be a sticker on the pump that notes the correct positions.
    17,000 Gallon plaster pool. Hayward Perflex EC65 DE Filter. 3/4 HP Hayward Superpump converted to dual speed. CircuPool RJ45. Skimmer, floor drain, two returns.
    22,545
    L1 is hot L2 is neutral. Unless it's a 240 volt pump. Or a 2-speed pump. or a 3-phase pump.
    How confused are you now???
    Jun 2010
    Toms River, NJ
    80
    MMMMM... three phase pump. Now we're talking some serious GPM! Sadly most utilitys in my area will not drop 3 phase at a dwelling.
    18'x24' (10,000 gal) above ground pool, 19" Proline sand filter (45 GPM), Jacuzzi 1.5 HP 2 speed pump
    22,545
    Not quite as serious as you might think. All those fancy variable speed pumps out there are 3 phase. The drives convert single phase power to 3-phase.
    Thanks to help from you guys, the pump install was easy. The only problem I had was the wiring didn't conform to standard color codes...the hot and neutral were grey and lt blue. I took a guess and hooked them up. The pump fired right up, but relatively low flow out the return. I reversed the connections and all was well. My neighbors will be happy too, since the new pump is so much quieter. How did we get along before on-line forums??
    South Central NJ
    3,192
    Peeps like me made more money.
    Scott
    Just found this old post.... I cant get my new motor to prime... Is it possible my wiring is also not what I thought it was????? Anybody have any thoughts on this????
    Cleveland, Ohio
    IG 36,000 gallons. Vinyl Liner, Hayward ProGrid 3620 DE Filter, Hayward Super Pump, Hayward Gas Heater
  20. Back To Top    #20
    Pittsburgh, PA
    15
    I, too, have a Haywood 1.5 HP pump (8G05) ... It (and the pool) came with the house I bought, so since I wasn't there when it was installed, I'm catching up on pool things I should know. And now, since the motor has developed a relatively high-pitch, metallic whirr on top of it's normal sound, I'm guessing I need the bearing replaced. Or something.
    Anyway, First things first ... Can anyone tell me how to disconnect the electrical wires on this pump? I unscrewed the cap at the rear of the motor to reveal the wires, but there doesn't appear to be an obvious point to disconnect/unplug it so I can safely take a look inside. Any help would be appreciated.
    * Bought a home 2010 with a vinyl IG, believed to be 8,800 gallon
    * Hayward 3025 Swimclear filter, with Hayward 1.5HP Super Pump ... 50.76 GPM
    * TF100 testkit
